LS/B20 Block, GSR/ITR Crank, Which Main studs?
I don't see any reason why using a GSR crankshaft on my B18B would change the mainstud required.
I have noticed that nobody seems to stock (or ARP does not make) main studs for B18B engines?
It depends on whether you use a girdle or not.
If you use a girdle, then you need the (6) longer main cap bolts. The (4) on the ends are the same.
ARP does make....or rather I should say that they adapted a kit for girdled and non-girdled B-series motors.
Read before you buy:
https://honda-tech.com/zerothread?id=647246
m4xwellmurd3r
Apr 29, 2013 09:25 PM
ruffrhyder
Apr 2, 2009 03:32 PM
ForceFed_DA
10
Mar 31, 2008 07:37 PM
