milling the head
Old Feb 26, 2004 | 11:02 PM
thehatchninja's Avatar
Default milling the head
what's up guys
plans for the 93 ex
buy a spare f22a6 head
professional p&p
delta cam
milled as much a possible
thinner head gasket if possible
h23 tranny
h23 IM
h23 TB
goal is low - mid 15's all mota
so as the topic says, my question is aboutt milling the head...does anyone know the max the head can be milled? also is there a thinner head gasket that we can run on this thing?
Old Sep 13, 2005 | 12:34 PM
exratedaccord93's Avatar
Default Re: milling the head (thehatchninja)
anyone know the answer to this? I'm going to mill my head to bump compression and would like to know how much i can go and still have valve clearance. thanks for the replies in advance
Old Sep 13, 2005 | 12:49 PM
d112crzy's Avatar
i think .030" is the most i would go. but i dont think milling the head and getting a thinner HG is gona be a good idea.
also, if ur gona get another head, make it an h23 head, if ur gona upgrade, upgrade the most u can. it swaps right on, its not difficult to do, its been done before, and plus the stock h23 on the f22 block would put u at 160hp, and 9.2:1 cr, then, you wont need to mill as much, and then u can get the PnP to get it to flow even better. iuno, just my .02 cents.
Old Sep 15, 2005 | 08:03 AM
i_kick_turtles's Avatar
Default Re: (d112crzy)
I'm not going to get into the evils of head milling but I'll put it this way: If you have $1000 of PnP work in your head and you overheat, it's done. All that money goes down the drain cause you can't mill anymore.
If you're gonna mill do it right, mill the block, or even better get higher CR pistons. Race Engineering sells 11:1 pistons reasonably, but I'm guessing you don't want to get into the bottom end.
Milling the head .010 will bump you up to like 9.2:1, .030 = 10:1. You will also need a cam gear because milling will require you to advance timing. Rule of thumb: for every .012 milled advance cam timing 1 degree.
For a thinner head gasket get a three layer OEM gasket, take the rivets out, spray the middle layer with copper spray and use it.
Also consider porting the throttlebody and portmatching your header.
michaelprice83
Sep 22, 2008 09:28 AM
WiteSiprelude
Oct 8, 2004 06:03 AM
IcePenguin
Apr 6, 2004 07:24 AM
kuya kanin
Apr 22, 2003 09:09 AM
str8rcn
Mar 8, 2002 09:10 PM
