Honda S2000 Honda S2000
I need advice on the NEUSPEED springs
Old Feb 26, 2004 | 06:57 PM
tmkpres's Avatar
Default I need advice on the NEUSPEED springs
Like the topic says has anyone had problems with them being to soft? Is there some pics that I can see a s2k droped on them?, thanks for the help !
Old Feb 26, 2004 | 08:07 PM
evil vapor's Avatar
Default Re: I need advice on the NEUSPEED springs (tmkpres)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmkpres &raquo;</TD></TR><TR><TD CLASS="quote">Like the topic says has anyone had problems with them being to soft? Is there some pics that I can see a s2k droped on them?, thanks for the help !</TD></TR></TABLE>
what's the intended purpose of the car?
Old Feb 26, 2004 | 08:41 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Eibach, y0.
Old Feb 26, 2004 | 08:43 PM
evil vapor's Avatar
Default Re: I need advice on the NEUSPEED springs (vtecvoodoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecvoodoo &raquo;</TD></TR><TR><TD CLASS="quote">Eibach, y0. </TD></TR></TABLE>
shameless plug
Old Feb 26, 2004 | 09:58 PM
AWD: Jeff's Avatar
Default Re: I need advice on the NEUSPEED springs (vapor)
i have kgmm race w/ koni's, no problem here.
Old Feb 27, 2004 | 07:12 AM
DongTran's Avatar
Default Re: I need advice on the NEUSPEED springs (Eh2 to Ap1)
these pix below were when I had neuspeed springs + stock shocks
Honestly it feels the same as stock, if not a bit firmer.
Old Feb 27, 2004 | 09:28 AM
Mr. Bagel's Avatar
the main problem you run into with the Neuspeed springs would be the amount of negative camber. it is so drastic that well... you end up with -2.8 and that's about as postitive as you can go. other than that, they will not be too soft. but it really depends on the intended purpose of the car itself: i.e. - track, street, etc. because there are of course, more tunable setups out there, and they cost money. but you get what you pay for.
Old Feb 27, 2004 | 04:45 PM
mugenefcivic's Avatar
i think you should wait until you have enough money for tien`s ,that`s my $0.02 oh and by the way grap line`s 1,2,3,4 there all report call`s j\k lates.
Old Feb 27, 2004 | 05:27 PM
tmkpres's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">
what's the intended purpose of the car? </TD></TR></TABLE>. Im going to use the car to daive daily maybe do a little auto X but for the most part it will be a street car. Plus I woull really like to get rid of the gap between the tier and fender .
Old Feb 27, 2004 | 06:20 PM
AWD: Jeff's Avatar
heres mine when it was stock
look how high that is, look at the wheel gap in the front
it was begging to be droped a bit
and heres when i got koni yellows w/ kgmm race springs
Old Feb 27, 2004 | 06:21 PM
AWD: Jeff's Avatar
not my car, a person car on s2ki, heres koni yellows on the lowest perch w/ kgmm race springs
Old Feb 27, 2004 | 07:15 PM
tmkpres's Avatar
You have the yellows also, but are yours at the lowest pirch also ?
Old Feb 27, 2004 | 07:30 PM
AWD: Jeff's Avatar
i have the fronts on the lower perch, and the rear at the top, because most people have a problem like this.
http://forums.s2ki.com/forums/...=kgmm
http://forums.s2ki.com/forums/...+race
btw, if u have the oem lip sometimes it maybe difficult driving up driveways, i scrap on mine if i dont profile my car.
Old Feb 28, 2004 | 06:21 PM
tmkpres's Avatar
Default Re: I need advice on the NEUSPEED springs (DongTran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DongTran &raquo;</TD></TR><TR><TD CLASS="quote">these pix below were when I had neuspeed springs + stock shocks
Honestly it feels the same as stock, if not a bit firmer. </TD></TR></TABLE> Did you change your set up or are you still running it and if so do you like it !?
Old Feb 29, 2004 | 05:03 AM
nutsack's Avatar
here are the neuspeeds on my car, it feels like it oversteers a little less than with stock springs. mine is an 02 which for some reason are lower than the 00-01's with the same springs.
Old Mar 5, 2004 | 05:35 PM
tmkpres's Avatar
Default Re: I need advice on the NEUSPEED springs (*******)
******* thanks for the pic I really wanted to see the car sitting still to see what it will look like Thanks very much !
Old Mar 6, 2004 | 05:15 AM
OC 335i's Avatar
Looks good bro.
Old Mar 7, 2004 | 08:47 AM
AWD: Jeff's Avatar
Default Re: I need advice on the NEUSPEED springs (JMS JT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMS JT &raquo;</TD></TR><TR><TD CLASS="quote">
Looks good bro. </TD></TR></TABLE>
thanks, but i cant compare to your itr conversion on s2. haha
Old Mar 7, 2004 | 02:49 PM
MooreBoost's Avatar
I would reccomend Epelir or KG/MM over Neuspeed.
Old Mar 7, 2004 | 07:19 PM
OC 335i's Avatar
Default Re: I need advice on the NEUSPEED springs (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">I would reccomend Epelir or KG/MM over Neuspeed. </TD></TR></TABLE>
Why? What are the spring rates on all those?
Old Mar 7, 2004 | 09:07 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Why? What are the spring rates on all those?</TD></TR></TABLE>
Yes, please enlighten us all.
Ryan
Old Mar 8, 2004 | 03:57 PM
MooreBoost's Avatar
Espelir Active Super Down springs for s2000
Front 5.3 kg/mm - 313.60lbs
Rear 7.0 kg/mm - 392.00lbs
asergioc
Aug 15, 2007 03:35 PM
skeelo
Suspension & Brakes
18
Dec 10, 2005 09:46 AM
doggydog
17
Jan 9, 2005 01:39 PM
JDubya
Nov 25, 2004 10:14 PM
g2homboi
Feb 22, 2004 12:11 AM
