Sunroof stuck
Do you mean it just stops? Mine wouldnt just stop but would just have trouble, I rubbed some grease along the track and went back and forth a few times and a bit of wd40 and its back and forth fine.
Maybe something stuck in the track
Can you manually crank it back and forth? If so, then it may be the motor or the switch. There is a good thread on how to clean the sunroof switch on ht if you search. If you have any more questions ask.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iridebiketrials »</TD></TR><TR><TD CLASS="quote">it wont open or close all the way...any way to tell if its the motor and also how hard is that?</TD></TR></TABLE>
Try a new switch!
A bad switch will cause it to seem like it doesn't have enough power. Bad SR switches are also common on CRX's.
Good luck.
Try a new switch!
Good luck.
io_burn
14
Feb 25, 2002 05:07 PM
