Dri. Side shaft removal?
Old Feb 26, 2004 | 05:04 PM
RicedREX's Avatar
Default Dri. Side shaft removal?
is it pretty easy to take off my driver side axel? Do most come out aftrer taking off the nut under the caliper??? any common complications? I need to know thanx.
Old Feb 26, 2004 | 05:08 PM
91civicDXdude's Avatar
1. loosen the axle nut with the car on the ground
2. jack the car up
3. remove the wheel
4. loosen the lower ball joint nut after removing the locking pin
5. seperate the ball joint and pull the hub assembly outwards and seperate the axle from the hub.
6. pry the axle from the transmission using a screwdriver or small pry bar
7. pull the axle free
installation is reverse of removal
Old Feb 26, 2004 | 05:10 PM
Mr Furball's Avatar
Default Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">1. loosen the axle nut with the car on the ground
2. jack the car up
3. remove the wheel
5. separate the ball joint and pull the hub assembly outwards and separate the axle from the hub.
installation is reverse of removal</TD></TR></TABLE>
Holly crap,
You do post useful information
Old Feb 26, 2004 | 05:19 PM
Kasper.'s Avatar
Default Re: (Mr Furball)
I just did this last night at work, although I had air tools it is a ver simple job, and I was done in a half an hour.
One thing ^ he forgot to mention, unbolt the through bolt on the lower control arm for the bottom of the strut assembly, this way you can pull up/down on the control arm easier, and also get the old axle/new axle in easier.
Old Feb 26, 2004 | 05:33 PM
Default Re: (Kasper-EF8)
whoops i knew i was forgetting a step
lowtegsr
Feb 1, 2008 07:18 AM
Mr. Giggles
Jan 23, 2007 06:15 PM
Ammadien
15
Jul 14, 2006 05:00 PM
CRX_Control
Apr 7, 2006 07:30 PM
kshymkiw
Dec 5, 2002 06:56 AM
