how much does it cost for compression test on prelude 2.2vtec
Old Feb 26, 2004 | 04:57 PM
1SOL2NV's Avatar
Default how much does it cost for compression test on prelude 2.2vtec
i'm looking at getting the prelude and everyone say to have a compression test done well the thing is the car is about and hour and half away from my house and its at a car lot as is and they want 12 for it the motor has 91,xxxx on her what should i do
Old Feb 26, 2004 | 05:02 PM
biglew's Avatar
Buy a compression tester from an autoparts store and do it yourself. It's a simple process.
Old Feb 26, 2004 | 05:08 PM
Revi's Avatar
Default Re: how much does it cost for compression test on prelude 2.2vtec (1SOL2NV)
Well a dealership will charge you about $100 for the test, although i doubt the sales person is gonna let you take the car to honda to get checked out. If they let you do it, just buy a tester at your local autoparts store and do it your self.
You could always bring a personal mechanic who you trust and knows what he is doing. Or you can do a quick visual and sound check:
1. Check for oil leaks on the floor, around all gasket/seal areas (Oil pan, head gasket, valve cover, distributor side of the head, tranny, ect.)
2. Listen for abnormal sounds from the engine at idel and under load.
3. Test drive the car and check for grinding (if manual) or ruff shifting.
4. Check your coolant. Make sure it is not a weird color and check the reservoir.
Or best yet, tried to find a RSX-S or ITR and race it, if your neck to neck or win....you got a healthy one!!
Old Feb 26, 2004 | 05:26 PM
fastludeh22's Avatar
what year is it? i got a 4th gen i may be selling this summer....that is if you think you can handle 500 whp.
but ya, just buy a compression tester for 15. take it with you. pull a plug out, disconnect the distributer wires screw in the tester and crank the engine.
w/91k expect about 200 psi, and not more then 10-15 psi varience per cylinder
Old Feb 26, 2004 | 05:28 PM
Default Re: how much does it cost for compression test on prelude 2.2vtec (Revi-Ra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra &raquo;</TD></TR><TR><TD CLASS="quote">Or best yet, tried to find a RSX-S or ITR and race it, if your neck to neck or win....you got a healthy one!!</TD></TR></TABLE>
lol, dont think the seller will like that to much...but it would work
Old Feb 26, 2004 | 06:53 PM
vinuneuro's Avatar
doesnt 12 sound really high? When i looked at ludes ones with 90k were 6-7k and ones with 40-60k were around 8-9k. I personally got mine 5 months ago with 56k on it for 5.6k. not car lot. acura dealer. be careful with car lot. the ones i looked at lots were really in pathetic condition.
Old Feb 26, 2004 | 07:35 PM
1SOL2NV's Avatar
Default Re: how much does it cost for compression test on prelude 2.2vtec (vinuneuro)
well it has been hooked up so i'm not real sure looked at blue book for it and its dead on for there price its a 1998 sh it has mods such as i/h/e and has been lowered and has the honda optional bodykit but it ran really good
Old Feb 26, 2004 | 07:38 PM
biglew's Avatar
Modifications take away value.
Old Feb 26, 2004 | 07:41 PM
99spanishGT
Guest
Posts: n/a
Default Re: (biglew)
yeah bro 12 is way to much id say more like 9k
Old Feb 26, 2004 | 07:42 PM
tuan...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote"> doesnt 12 sound really high? When i looked at ludes ones with 90k were 6-7k and ones with 40-60k were around 8-9k. I personally got mine 5 months ago with 56k on it for 5.6k. not car lot. acura dealer. be careful with car lot. the ones i looked at lots were really in pathetic condition.</TD></TR></TABLE>
ur thinkin 4th gen..
Old Feb 26, 2004 | 08:44 PM
1SOL2NV's Avatar
Default Re: how much does it cost for compression test on prelude 2.2vtec (h22a4_dc2)
it's a late model 98 not an older one
Old Feb 27, 2004 | 08:50 AM
Accel Junky's Avatar
A compression test is sooo easy. You buy a compression tester for $20 (or borrow one), and it basically threads in to where your spark plug would go. You remove the fuse for the fuel-injection system and crank the motor over till the tester stops reading out. Record results and replace spark plug. Repeat for all cylinders.
Old Feb 27, 2004 | 12:22 PM
1SOL2NV's Avatar
Default Re: (Ibuprofec)
thanks for the how 2
Keeper1343
Dec 17, 2007 09:10 PM
94_civic_tuner
Oct 10, 2007 02:00 PM
professorman
May 2, 2007 01:02 PM
gmacarize
Jul 28, 2006 08:39 AM
Typeron
Jan 5, 2006 07:37 PM
