D16a6 series tranny, how do I tell what year it is?
...As the title suggests.
The previous owner dropped in a '91 motor (the car's an '89) but I'm unsure what tranny its running. I know its got to be a '89-'91.
Basically, I need to pick up a clutch but they list different model years. 88, 89, and 90-91
no way to tell the year by looking at it in the car - what you really need to know though, is what year flywheel it has - if the transmission is not 88, then the difference is in the flywheel - 89 had flywheel for 200mm clutch - 90-91 had flywheel for 212mm clutch - the reason they are listed different is 88 Si had 21 spline hub for input shaft, 200mm dia. - 89 had 20 spline hub for input shaft, 200mm dia. - 90-91 had 20 spline, 212mm dia. - just find 90-91 flywheel and buy larger 90-91 clutch
Thanks.
Well seeing as its a '91 motor, wouldn't it have a '91 flywheel? Sorry, I'm kind of a noob when it comes to clutches. Is there any way to tell what year the MOTOR is for sure?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dgonzals »</TD></TR><TR><TD CLASS="quote">does it have any numbers on it? postem.....</TD></TR></TABLE>
I'll try to find them when I get home from work, where abouts should I be looking?
91 transmission will fit 88 if you use 89 clutch (if your 88 is Si) - if it is not Si, then you need 89 clutch and 89 flywheel or 90-91 clutch and 90-91 flywheel
user 98292739
May 6, 2007 12:32 PM
Servo
Oct 14, 2005 06:37 AM
