CEL #71 and #72
Hi all, getting this CEL (71 & 72) with my new ECU, anyone know what it is? It's not in my Helm's. Program is based on a JDM ITR w/OBD II removed. Took a couple of days to show up. Any ideas would be greatly appreciated
Its in the 96+ helm because its an OBD2 code.
Misfire cylinders 1 and 2
Apparently, you have a USDM program.
FYI, my stock ECU picks up 71-74 all the time. Nothing is wrong, my guess is it
has something to do with the slight lope of the cams throwing off crank/cam timing.
The misfire code is a result of a discrepency between a sensor in the distributor(CYP i think)
and the CFK sensor.
and the CFK sensor.
Chad, yea do you have your intake cam gear adavnced past +1?
Once my tuner i did mine that code comes up, i think also its the lumpy idle, my tuner said as long as they are adjusted i will have that code...lol.
But no worries its all good.
So hows the si running?
lata
lata
Car runs nice and strong. No issues except for the damn CEL. Maybe I should cover it up with some tape
j/k
Glad to know I'm not the only one with this code.
j/kGlad to know I'm not the only one with this code.
Sgt, does your car go into limp? Or do you just drive with the CEL on and codes flashing? Just curious, cuz I'm thinking of running Toda B's and stock ECU. So I wanted to know if thats something to expect.
So that is why I get that code...
I have a Yoshio ECU with spec b's.... I never thought it was so bad, but it is interesting to hear why it may be happening.
Thanx guys.
Thanx guys.
killaj12
Mar 5, 2007 04:16 AM
MintyDip
Jan 21, 2002 09:37 AM
