will rear gsr seats fit in a 91 hatch?
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
i think 90-93 integ seats might fit....94 and up will fit but there will be little gap where the center plastic piece is at...correct me if i am wrong....thanks..
I put 94 ls seats into my 91 hatch, only one hole lined up.
I used self tapping screws for the other three points, not the safest but its worked for about 6 months now. When it gets warmer I wanna get around to modifying it so i can use the stock mounting holes.
From: chillin in that city called queen creek, but homes the atl
those are front seats what about the back. come on people i know somebody has done this. and i already did a search.
94+ integra rear seats will fit in an EF. Not a direct bolt up unless you take the metal skeletons out of your EF rear seats and put them into the Integra rear seats.
90-93 Integra seats will not work because they are not 50/50 split like the EF/DC rears. They are like 60/40 split or something. Although I'm considering hacking off the bracket thingy in the middle of where my EF rear seats bolt up, and moving it so the 60/40 DA seats will work since i've got a nice set of 92 GS-R front and rear seats.
i know this for sure because i did it myself on a 91 si hatch.....
i used 90-93 black leather integra seats all around. the front ones i got 3 bolts in, it takes a while but screw them in diagonally kind of and you'll get all 3 in.
the back seats worked good but i took the stock seats out and grinded down the middle piece thats on the body (where you sit) then i lined up the bottom part and used zip ties to hold it down and it worked perfect
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c8r9x »</TD></TR><TR><TD CLASS="quote">zip ties</TD></TR></TABLE>
that sounds safe.
that sounds safe.
