Car wont start, exhaust putts loud?!
Old Feb 26, 2004 | 10:47 AM
Toptul_Honda's Avatar
New User
Default Car wont start, exhaust putts loud?!
I stored my car and it was runniny like crap. I have added lots of additives
Like methyl hydrate, injector cleaner, and water remover.
The car was running ok until today when i ran it, then stopped it and tried to run it again. When i do turn it on, the car wont start and the exhaust putts loud.
the exhaust sounds like its backfireing..
do u think that there was water in the system that would have caused the engine to freeze and not start?!
HELP!
Old Feb 26, 2004 | 01:05 PM
sporkcrx's Avatar
Default Re: Car wont start, exhaust putts loud?! (G2-Rex)
Sounds to me like timing problem. I would check that first then move on
enhancedCL9's Avatar
check distributor
Old Feb 26, 2004 | 01:58 PM
TiggsCRX's Avatar
does it sound like mine? heh, I put a post up with a vid clip, search under my name you'll see it...heck here's the vid clip http://www.ctel.net/~wilfredb/mov00054.mpg
I've been told timing, I just checked the distributor and actually flipped it 180 degrees inside and got the car to combust, wahoo! but anyway, reset the timing, mine is still a little off but I think that's the key! timing sucks! haha. it's easy though especially if you got access to an impact wrench!
Old Feb 26, 2004 | 05:15 PM
New User
Default Re: (TiggsCRX)
ok well i started it up again and it worked.... odd...
maybe it was saturated with fuel?
but if my car sits for a while, would timing change? Because when the car is running warm, the exhaust putts stilll....
Old Feb 27, 2004 | 06:52 AM
TiggsCRX's Avatar
I wouldn't think the timing would change just from sitting there, if the belt is loose somehow it may jump though and therefore change.
Old Feb 27, 2004 | 07:37 AM
Filthy Focker!'s Avatar
You had junk in your fuel circuit...
timing does not change on its own.......
fs
Old Feb 27, 2004 | 08:01 AM
BAZ's Avatar
BAZ
wow sounds like my problem https://honda-tech.com/zerothread?id=778152
Old Feb 27, 2004 | 06:24 PM
New User
Default Re: Car wont start, exhaust putts loud?! (BAZ)
if the fuel is crappy would it do that?
Old Feb 27, 2004 | 06:26 PM
New User
sweet thanks!
well the filter didnt change.. i guess ill add more additivesa
yo bj
Feb 2, 2011 05:54 PM
94preluder3084
Feb 19, 2007 10:25 AM
turboblkek
Sep 7, 2005 04:05 PM
Do_Ster
Jul 7, 2004 03:55 PM
white90si
15
May 22, 2003 09:08 PM
