***Upper pipe intake piece***
Does anybody know a short ram intake pipe that's bolt up to the oem intake box? I want an upper pipe that doesn't have a resonator and doesn't have ridges on the inside. Any pipe that doesn't retain a lot of heat will do fine (c/f or mandrel bent aluminium coated w/ heat resistant paint) will do.
You could get a CAI and set it up as a Wetlands setup. It's not ram air but not full CAI either. That's how I have mine. So check out either AEM or Iceman(what I have)...
But you want to use the stock filter box???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmlude_dude »</TD></TR><TR><TD CLASS="quote">Its called an AEM CAI with the air bypass valve!!
what??? I want the stock airbox, I don't want an exposed filter.
</TD></TR></TABLE>what??? I want the stock airbox, I don't want an exposed filter.
no.
</TD></TR></TABLE>no.
Well you could Ghetto Fab a pipe. Just go to Home depot and get ABS pipe and some silicon tubing for the connections... Or you could go somewhere and have one custom bent and powder-coated.. But then you might be getting into more $$ than it's worth. Also you could get a e-bay ghetto CAI and cut and mod it....
Ebay it up for the piping - and you should get at least one silicon connnector (pipe to TB). You could look for an intake with two connectors, or you could cut off part of your original intake tubing and use that as the connector to join the pipe and airbox. Or you could go find a silicon adapter. I know weapon-r (don't laugh) has couplers that go from 2.5" to 3" and so on.
