reusing cylinder head bolts?
Old Feb 26, 2004 | 10:04 AM
dan89crxsi's Avatar
Default reusing cylinder head bolts?
what are some opinions on reusing cylinder head bolts?
Old Feb 26, 2004 | 10:13 AM
doublejz's Avatar
Default Re: reusing cylinder head bolts? (dan89crxsi)
I have reused d16 head bolts like 3 times and b16 once without any problems. It is not recommended though, unless you buy some good AEBS or ARP head studs.
Old Feb 26, 2004 | 11:07 AM
Rtype16's Avatar
Default Re: reusing cylinder head bolts? (doublejz)
In a high horsepower motor I would never re-use bolts only studs.
Old Feb 26, 2004 | 12:47 PM
vtecb20coupe's Avatar
B A N N E D
Default Re: reusing cylinder head bolts? (Rtype16)
reusing them shouldn't be a problem as long as you reinstall them in the same order you pulled them and don't overtorque them.
Old Feb 26, 2004 | 12:58 PM
AzG35's Avatar
Default Re: reusing cylinder head bolts? (vtecb20coupe)
I believe that head bolts shouldn't be reused more than twice, but it is up to you. I know people that have done it, but once a bolt stretches, it doesn't hold as well as before. This is why headstuds are nice. You can reuse head studs many more times than bolts, because they stretch less and are not fatiqued as easy
Old Feb 26, 2004 | 07:19 PM
Kataku2K3's Avatar
Default Re: reusing cylinder head bolts? (AzSi22)
In some cases I've reused them numerous times so I really wouldn't be to worried... Don't get me wrong, on all of our higher compression NA or FI setups nothing but AEBS or ARP studs are used...
Modified by Kataku2K3 at 10:00 PM 2/26/2004
Old Feb 26, 2004 | 09:23 PM
ExospeedAMcrx's Avatar
in any case, whether it is the ARP or the Stock studs, its not recommended to reuse them.
Especially on high end performance motors. the most we reuse is 2-3 times on the AEBS or ARP studs.
Old Feb 26, 2004 | 09:43 PM
blackeg's Avatar
Default Re: (exospeedAMcrx)
im on the second time using my stock headbolts. no probs with them so far, but im not runnin any f/i yet. for serious setups id get new oem every time, or maybe reuse aftermarket ones once...
Old Feb 26, 2004 | 09:53 PM
mmuller's Avatar
Mad Scientist
Default Re: (blackeg)
I've retorqued mine 4-5 and no problems; but then again its not a wild setup.
Next time i take them out arp's or aebs are going in
Old Feb 27, 2004 | 05:49 AM
B A N N E D
if you need any b16a oem studs, i got plenty.
oranginal
May 2, 2006 11:14 AM
tom91ita
Sep 20, 2004 06:34 PM
iperez
Feb 11, 2004 07:21 AM
shamoo
Jan 21, 2002 02:05 PM
