Strut Bars PLEASE HELP 4 EM2 EP3 DC5
Hello,
Those should all be different applications. The DC5/EP3 use the chassis but the strut tower bars are different. The lower components on a DC5/EP3 are the same. Ie. you can use the same X-brace on both cars. However it will not fit on the EM2.
Please let us know if there are any other questions.
Thank you,
Thank you,
Upper Rears fit as long as they bolt to the towers and not not across the seat pass through (like the Mugen one), lower rears fit, the Upper Fronts do ONLY IF you don't have an aftermarket intake installed. The elbow in the intake piping because of the vertical throttle body won't clear the straight bars, you need a Neuspeed or DC Sports bar for the EM/ES. The lower front bars I don't know... I never looked into installing one. The rear swaybars can be swapped, the fronts cant.
kenjief8
Dec 30, 2004 06:59 AM
