DSM injectors with Resistor box on H22?
Old Feb 25, 2004 | 06:50 PM
Pikachu's Avatar
Default DSM injectors with Resistor box on H22?
I did a search and I'm unclear if the resistor box is required for this? I'm in the process of hooking up the turbo so the injector upgrade is definately needed. Do I need to run the resistor box or no? Engine is OBD1 if it matters. Please help. I want to hook them up this weekend. Thanks.
Old Feb 25, 2004 | 08:01 PM
TurboSam's Avatar
Default Re: DSM injectors with Resistor box on H22? (Pikachu)
what car is this going in?
Old Feb 25, 2004 | 08:38 PM
Perception's Avatar
Default Re: DSM injectors with Resistor box on H22? (Turbo Sam)
Good question
I'd like to know also
Old Feb 25, 2004 | 08:56 PM
KTeller8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Sam &raquo;</TD></TR><TR><TD CLASS="quote">what car is this going in?</TD></TR></TABLE>
by his sig:
92 Honda Civic CX
95 JDM H22 Motor
Boost is currently a work in progress
18G Greddy Turbo @ 7psi
i think its a civic with the h22 motor...
Old Feb 25, 2004 | 09:05 PM
Maintenance's Avatar
Default Re: DSM injectors with Resistor box on H22? (southwego)
I'm assuming that your ride is a h22 civic. So do you have it wired up for the resistor box? If you're using the 345 cc then it should be wired up. If so then I'm also assuming that you are probably going with the 450 dsm injectors. Then you dont have to worry about it. You should be good to go. You're going to need the resistor box regardless because the 450cc are also peak and hold. If my assumptions are wrong then disregard my answers.
Old Feb 26, 2004 | 04:56 AM
Pikachu's Avatar
I believe I have a resistor box hooked up. I'll have to check. I have stock injectors hooked up.
Old Feb 26, 2004 | 05:17 AM
TurboSam's Avatar
Default Re: (Pikachu)
what harness are you using, what car is this going in..... i am not going to make assumptions.
Old Feb 26, 2004 | 06:39 PM
Pikachu's Avatar
It's for the car in my sig. I have no idea what harness I'm using. But I don't see an indication of a resistor box.
Old Feb 26, 2004 | 06:52 PM
TurboSam's Avatar
then you need to wire in a resistor box
Old Feb 27, 2004 | 06:01 AM
96SR-V's Avatar
Default Re: (Turbo Sam)
Yes...been running this for a year now.
Old Feb 27, 2004 | 06:52 AM
Accel Junky's Avatar
Resistor box is small (about 2.5 x 3 x 1.5 inches) and looks sort of like a heat sink. There is a wiring diagram somewhere in a post on this site.
RicanRacer253
Oct 3, 2019 10:21 PM
more3688
Mar 10, 2010 02:57 PM
Creator
Mar 7, 2008 05:10 PM
garyc17
Jul 3, 2006 11:10 PM
huge230
24
Oct 3, 2005 11:41 AM
