would you buy this jdm teg with slight problem?
Old Feb 25, 2004 | 01:25 PM
CrazyModGSR's Avatar
Default would you buy this jdm teg with slight problem?
I am looking to buy this integra, however noticed that the gap between the fender and the hood is larger on the left side than it is on the right. What do you think? Could this be easily fixed?
Old Feb 25, 2004 | 01:26 PM
Default Re: would you buy this jdm teg with slight problem? (CrazyModGSR)
ps - if you can't see the pic, right click, then view image
Old Feb 25, 2004 | 01:27 PM
J-g-D-s-M-r's Avatar
i had the same problem. if it's a stock hood try adjusting the ***** on the radiator suppoer it's on the corner by the fenders. they are black and you turn them clockwise to lower and counter clockwise to raise. if that don't work, hood pins are another way. other then that. get a new hood.
Old Feb 25, 2004 | 01:32 PM
Default Re: would you buy this jdm teg with slight problem? (J-g-D-s-M-r)
it's a cf hood - not sure if i could use hood pins bcuz it's a full cf hood (ie: no fiberglass in the middle), and not sure if i can drill into it or not
djSideOne
Apr 4, 2005 10:56 PM
alias 33
Jul 21, 2004 03:23 PM
HotRodDelSol
Jun 14, 2003 07:01 PM
Reverend
Dec 17, 2001 12:52 PM
Jon7
Oct 17, 2001 06:09 PM
