Paiting Engine bay, Trunk and inside by myself?
Old Feb 25, 2004 | 01:11 PM
Alberto's Avatar
Default Paiting Engine bay, Trunk and inside by myself?
How hard is it to paint a teg shell on the inside (inside, engine bay, trunk, etc)?
Car is going from Red to Silver.
Any suggestions?
Old Feb 25, 2004 | 01:13 PM
^jefs0ng's Avatar
Banned
Long time my friend if you do it.
Old Feb 25, 2004 | 01:26 PM
Alberto's Avatar
Default Re: (#jefs0ng)
Time is not an issue. Can it be done?
Old Feb 25, 2004 | 01:27 PM
^jefs0ng's Avatar
Banned
Default Re: (Alberto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alberto &raquo;</TD></TR><TR><TD CLASS="quote">Time is not an issue. Can it be done?</TD></TR></TABLE>
Sure can. I'm going to attempt it over summer.
Old Feb 25, 2004 | 01:53 PM
918-Hatch's Avatar
Colorado <3
good luck man. be carful.
Old Feb 25, 2004 | 02:06 PM
Alberto's Avatar
Default Re: (Billy Blue Hatch)
Any advice when paint spraying?
Old Feb 25, 2004 | 02:58 PM
Full Race A6's Avatar
Man its easy to do. Just take your time and dont overfucking load on the paint, do multiple thin layers, not a think piece.
As long as you clean the area first, tape it off and take your time. You cant go wrong. Make sure you get the appropriate paint
Old Feb 25, 2004 | 04:53 PM
Usdm1's Avatar
Default Re: Paiting Engine bay, Trunk and inside by myself? (Alberto)
go for it.. I dunno about your handy skills, but if you have some common sence, it'll be easy. silver is a light color so.... it's harder to see runs or over spray ect.
I say go buy some single stage paint and clean the surfaces really good from dirt and oils. tape off areas, now spray just keep your hand moving when your spraying and you'll be fine.
I sprayed 5 completes and alot of little things. I learned on my own with single stage.
Old Feb 26, 2004 | 06:06 AM
Alberto's Avatar
Default Re: Paiting Engine bay, Trunk and inside by myself? (Usdm1)
I'm going with the Dupont Silver Metallic. What sanding, sealer/primer and spray gun should I go with?
Old Feb 26, 2004 | 08:12 AM
model x's Avatar
you shouldn't need to prime and to prep the surface just clean alot with lacquer thinner and scuff the surface with a 3m scotch pad, you can get them at an autobody supply shop.
The hardest part is reaching everywhere, especially the hatch area.
Here's mine
Old Feb 26, 2004 | 05:59 PM
Alberto's Avatar
Default Re: Paiting Engine bay, Trunk and inside by myself? (model x)
how much paint for trunk, engine bay and interior?
VTECdohcter
Mar 17, 2010 08:06 PM
MNsnowdaboy
Paint and Body
Jan 20, 2008 08:21 PM
rasinhell
Mar 10, 2005 11:30 AM
notstock93
May 24, 2004 06:43 PM
