4th gen Prelude Fog light Q?s
Since my last post was deleted by power hungery Mods. Here is a tech question. Since my Fog-lights didn't come with the Sub harness, relay and switch what are my other options in wiring up the lights without making it look like crap.
you will not need the subharness...all it does is extend the wires long enough so that the relay can be mounted in the location designated by Honda...u can still find relays at the Honda dealer...now depending on the year of your prelude, the location of the switches will be different, as well the actual switch itself...i kno that the 94-96 switches are really hard to come by and that the JDM switches will not plug-and-play...The 92-93 Ludes have a different switch that goes where the front drivers side tweeter covers go...cuz behind that is where you will find the wires for the switch....best way to do it is get a relay, and figure out the wiring for the switch and run it another switch from radio shack or something...
Hello,
I have just found myself to be in the same spot (wiring the fog lights on my 95 prelude)
Ok, anyone out there please help us...
I am trying to wire up my FoG lights... I have (2) Different MALE conections under my dash, Colors of the conections are Brown (1) has three wires, the other has four... I know they have something to do with my fogs...Plus there is another MALE conection under my center console (WHITE) HAS three wires....
I am not trying to take over this thread but if any can help us out.. It would be sweet!!!!!!
I know the whit connection goes to the switch for the fog lights...
What about the 2 brown connection?? One must go to a rely while the other plugs in to the fuse panel???
I know someting is going to get blown the h*ll up if i don't wire this up right! LOL
one of the two connector under the dash is for the relay and the other one is for something else that you dont need for the fogs. i got my relay from a civic foglight so maybe you could try it. heres the site.
http://www.hondaautomotivepart....html
i can seem to find my harness for the switch. i got a 95 so it should be under the console, right? i thinks ill just chech behind the tweeter cover just in case.
94vtecmn
Mar 31, 2004 12:31 PM
