Factory Head unit removal
Remove the center console starting from the back armrest. Then the forward part, then the ashtray and cupholders, and THEN the head unit can finally be removed. WARNING! It's a major bitch.
there are two phillips head screws that hold your radio in from behind. You get to them by looking up from behind the center dash. undoing these 2 screws will allow your radio and dash pocket to come out, as the are connected. then you can install your new radio. entire console removal is not needed!!!!!
Tumblweed is pretty close...
First off... removing the center console area will make the job easier, but it not needed if you don't mind working in tight confined areas.
First off.. what year integra are we talking about (a 2000)? They are all pretty close the the same procedure. If you do not remove the center console (the way I do it) you can get to the back of the radio from the passenger side. get behind the center console from the passenger side, there are usual 2 bolts/screw. I have seen different bolts/screws that hold it in, but you will find either philips head screws, or 8mm nuts on the back.. they are difficult to see, but if you follow the radio back the the rear support you will see them..
Also, If your installing a new aftermarket radio, PLEASE buy a dash kit and wiring harness..
From: You can be my wingman anytime...., Las Vegas, US
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95tegLSS »</TD></TR><TR><TD CLASS="quote">
If you do not remove the center console (the way I do it) you can get to the back of the radio from the passenger side. get behind the center console from the passenger side, there are usual 2 bolts/screw. I have seen different bolts/screws that hold it in, but you will find either philips head screws, or 8mm nuts on the back.. they are difficult to see, but if you follow the radio back the the rear support you will see them.. </TD></TR></TABLE>
That's the easy way.
,but it's more fun to take out your center console and such.
texasnick
Jan 25, 2005 11:06 PM
88civicHB703
Audio / Security / Video
Jun 19, 2003 09:38 AM
