Jerking at WOT Please Read for explanation
Old Oct 13, 2001 | 03:13 PM
Comptech98GSR's Avatar
Default Jerking at WOT Please Read for explanation
sometimes my car when at WOT will jerk, happened the other day a couple times in 2nd gear, it just feels like it stops pulling for a split second, and then goes back to normal. Could it be my plugs,wires? My idle is normal, this is just a recent problem
Old Oct 13, 2001 | 03:17 PM
Chris's Avatar
Default Re: Jerking at WOT Please Read for explanation (Comptech98GSR)
Sorry...
Are you hitting the REV limiter????
agin sorry! I cant think of anything it might be...distributor?
Old Oct 13, 2001 | 03:21 PM
Default Re: Jerking at WOT Please Read for explanation (Chris)
no i 'm not hitting the rev limiter, it usually occured around 4K to 6K
Old Oct 13, 2001 | 03:38 PM
Leimokei's Avatar
New User
hmm, it might be your vtec point of engagement, do you have vtec controller or something like that, might want to reset your ecu...
Old Oct 13, 2001 | 04:27 PM
Anthony K's Avatar
New User
Default Re: Jerking at WOT Please Read for explanation (Leimokei)
check your ignition system. Mine did the same thing a while back and I found out it was the rotor.
Old Oct 13, 2001 | 05:09 PM
Default Re: Jerking at WOT Please Read for explanation (Anthony K)
hmm ok thanks, i think i will chekc my ignition system. my vtec point is stock, i don't have a VAFC or anything
Old Oct 14, 2001 | 12:49 AM
Mr. Softee's Avatar
check your oil.. sounds like low oil to me.
Old Oct 14, 2001 | 01:07 AM
Default Re: Jerking at WOT Please Read for explanation (97lstegra)
i am goign to try to change out my plug wires,and see if that cures the problem. i'm sure my oil is fine. I just checked it last fillup and it was fine.
Old Oct 14, 2001 | 08:27 AM
Asahi's Avatar
Sounds like low oil to me too. Almost sounds like limp mode but not.
Old Oct 14, 2001 | 03:11 PM
Default Re: Jerking at WOT Please Read for explanation (Carlex)
well, just checked my oil, and i was about a quart and a half low. pretty pissed about that, But the jerking still continued after i filled it up. It's not so much jerking as it is, stopping or hesistating throughout the powerband
Mason Fraser
Oct 7, 2012 05:37 AM
baggedeg
Honda S2000
Jun 12, 2010 06:21 PM
2k1 GSR
Mar 14, 2005 10:39 AM
danacixem
Aug 10, 2004 01:13 PM
ITR 0206
Aug 22, 2001 12:18 PM
