HELP! need an equivalent part for the water outlet casting for a DOHC JDM ZC
hey guys
just finishing the install of my rebuilt '91 DOHC JDM ZC into my '91 Civic Si.
The very last fastener to tighten up was the coolant bleed screw on the water
outlet (on the head), and of course the casting cracked, spilling coolant every-
where and putting my install into OT. My question is what the hell USDM part
is equivalent to this casting? To clarify, it is the part that bolts to the head that
has the bleed screw and the stub for the upper rad hose.
any help appreciated, as I lose my garage in two days!
thanks
greg v
thanks
greg v
you should be able to use the wter outlet from a First gen (86-89) integra for it. Same block and head, just different engine code.
picked up a D16A1 part just now and it is identical (except its not busted...)
thanx
greg v
thanx
greg v
CivicUtah
13
Sep 25, 2007 08:25 PM
GroundZer0
12
Aug 15, 2002 07:19 AM
