Brake change..
Old Oct 13, 2001 | 01:42 PM
Type Goch's Avatar
New User
Default Brake change..
yesterday i tried to change my front pads, but for some reason i could NOT get the bolts on the calipers off. With all my might it would not come off. I didnt use a socket wrench but some other wrench im not sure what it was called. I even tried using the penetrating lubricant but no luck..Any tips on what to do or which tools to use?
Old Oct 13, 2001 | 02:07 PM
ITRbroham's Avatar
shit post warrior
Default Re: Brake change.. (Type Goch)
Uh oh..... James
U probably used a crescent wrench which is probably the best to use. Dont use a socket becuase it will be easier to strip the bolt.
Which way were u turning the bolt? U should have been turning it clockwise! hopefully you didnt overtighten it.
I hope this helps!
Old Oct 13, 2001 | 02:50 PM
Floyd's Avatar
Default Re: Brake change.. (ITRbroham)
Keep in mind that the torque spec on the front caliper bolts is 36 ft-lbs, so if you were using a small crecent wrench you would have needed to apply more like 80 to 90 lbs to get it to budge.
Just a thought...
Old Oct 13, 2001 | 05:17 PM
GRM Scott's Avatar
25 Year Member
Default Re: Brake change.. (Floyd)
I used a gorilla breaker arm with a socket to get mine, it took some doing but the arm is about 18 inches extended, so you get mad leverage. A crecent is better for higher loads? I'd think that 6 points of force would be better than two, and most modern sockets have convex faces that put force towards the center of the bolt sides, not at the edges where they're likely to strip.
RIMPR
Honda Civic (2006 - 2015)
May 23, 2015 06:05 PM
Hatch1990SI
Apr 28, 2005 08:08 PM
Deano_D aka "Brick Top"
14
Feb 21, 2005 12:37 PM
GSR -97
Feb 16, 2002 12:15 AM
momo48
Jan 28, 2002 08:38 PM
