Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
TURBO RACE BLOCKS: Custom built by EXOSPEED Race Engines
Old Feb 24, 2004 | 11:27 PM
ExospeedAMcrx's Avatar
Default Turbo Race Blocks: Custom built by Exospeed Race Engines
Exospeed Race Engines:HT Special
Competition Race Engines by Exospeed Racing. Built by our in house race engine specialists. Each race block is designed to each racers needs.
From street performance to all out Full race setups, We can help design a package for you.
Many different stages to choose from. Check to see if there is a setup that is perfect for your needs.
Note: Every part used is Top Quality Parts. We only use Honda Bearings and Honda oil pump, water pumps and gasket sets. You won't see non-honda bearings or aftermarket replacement parts on our Race Engines. All block packages require core.
Honda part# labels are available on request to ensure you are receiving top quality OEM parts.
All block packages come with the following:
1. New OEM Honda Bearings (each measured to spec, no UNIVERSAL bearings used here)
* Each bearing size is measured by precision tools to ensure the most accurate clearances. NO Plastigauge here.
2. New OEM HONDA VTEC Oil pump
3. New OEM Honda Water Pump
4. Micropolished crank
5. Bottom end Gasket kit
6. Bore, Hone, deck, hot tank, R&R rods(if neces)
7. Assembly of block
B-Series
Turbo B16/B18 race/street block $1645.00
1. Arias 81.5mm 10.6-12.2:1 pistons w/ rings (compression will depend on the head and block used)
B16A head-B16Block 8:1 or 9:1
B16A head-LS Block 9:1 or 10.1:1
GSR head-LS block 9.2:1 or 10.4:1
GSR head-GSR block 9:1 or 10.1:1
2. Stock rods
Turbo B16/B18 race/street block $1955.00
2. Eagle Rods
Turbo 83mm B16/B18 race/street block $ 2695.00
1. RS Machines Sleeving
2. Arias 83mm pistons w/ rings
B16A head-B16 block 8.3:1 or 9.3:1 83mm
B16A head-LS block 9.4:1 or 10.4:1 83mm
GSR head-LS block 9.5:1 or 10.7:1 83mm
GSR head-GSR block 9.4:1 or 10.5:1 83mm
3. Eagle Rods
Turbo 84mm 1.8L-B16 /2.0L race/street block $ 2695.00
2. Arias 84mm pistons w/ rings
B16A head-B16 block 8.2:1 or 9.5:1 84mm
B16A head-LS block 9.2:1 or 10.6:1 84mm
GSR head-LS block 9.2:1 or 10.9:1 84mm
GSR head-GSR block 9.2:1 or 10.8:1 84mm
3. Eagle Rods
Turbo Custom Bore / Custom Piston Race block $2845.00
2. Exospeed Race sleeves
3. Eagle Rods
4. Arias Pistons: custom bore, custom compression to your specs
For the D-series Fans out there
D16A6, D16Z6, D16Y8, D16Y7
Turbo D16 $1645.00
1. Arias pistons w/ rings
D16A6 setup: 8.5:1 75.5mm
D16Z6 setup: 9:1 75.5mm
D16Y7 setup: 9:1 75.5mm
D16Y8 Setup: 9.3:1 75.5mm
2. Stock rods
Turbo D16 w/ Eagle Rods $1965.00
Turbo D16 Street/Race block $2695.00
1. RS Machine sleeving
2. Eagle Rods
3. Arias Pistons w/ rings(see compression above)
Turbo D16 Race block $2845.00
1. RS Machine sleeving: your specified bore size
2. Eagle Rods
4. Custom bore and compression size
H-series: consult us for specific compression choices
Our competition race blocks are High Quality precision built for the best performance possible. Not only do we build top notch engines, but we race them as well. So you will get technicians that can guide you to the proper setup you will need.
Our race engines are used in competition in the NHRA, IDRC, NDRA and Battle of the Import in the PRO and Street classes. Choose us for your race block needs.
Exospeed Racing Products “Honest work, done with Pride”
Modified by exospeedAMcrx at 9:01 PM 2/25/2004
Modified by exospeedAMcrx at 6:40 AM 3/3/2004
Modified by exospeedAMcrx at 7:25 AM 3/4/2004
Modified by exospeedAMcrx at 8:11 AM 3/4/2004
Old Feb 25, 2004 | 08:02 PM
any questions and if you want to discuss a setup you are thinking about.. feel free to email, call us or PM.
thanks
Wil
Old Feb 27, 2004 | 05:55 AM
drumking15's Avatar
Wil slight problem in your b series builds...esp your 83mm...it comes w/ 84mm pistons gonna be kinda hard to squeeze in there dont ya think...
Old Feb 27, 2004 | 07:49 AM
Default Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 &raquo;</TD></TR><TR><TD CLASS="quote">Wil slight problem in your b series builds...esp your 83mm...it comes w/ 84mm pistons gonna be kinda hard to squeeze in there dont ya think... </TD></TR></TABLE>
haha.. you're right. dang i need an Editor for my posts man. thanks for the heads up. i'll update it later.
Old Feb 27, 2004 | 10:00 AM
Farmer Brown's Avatar
Default Re: (exospeedAMcrx)
I'll take a turbo D16 please. Oh wait.. I have no money.
Old Mar 2, 2004 | 11:55 PM
Default Re: (Djaric)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djaric &raquo;</TD></TR><TR><TD CLASS="quote">I'll take a turbo D16 please. Oh wait.. I have no money. </TD></TR></TABLE>
you dont have the full amount now? we have payment plans. if you arent familiar with it, hit me up and i'll let you know how it works.
Old Mar 3, 2004 | 02:35 AM
quik sol's Avatar
can you pm me a price to start a payment plan on this option:
B16A head-B16 block 9.5:1 84mm
3. Eagle Rods
Also when does this offer end? I am still saving up the money for the stinking head package you got going til the end of march....could I just send you the whole engine instead of sending them at diff times? I just really love yalls deals you got going...
Old Mar 3, 2004 | 05:34 AM
Default Re: (quik sol)
pmed Quik Sol
Old Mar 3, 2004 | 06:46 PM
cracker099's Avatar
Bump ^^ and you have PM
Old Mar 3, 2004 | 08:04 PM
quik sol's Avatar
i never received pm? and also for that package what would be it be I had my own rods? (full-race rods to be exact)
Old Mar 4, 2004 | 07:13 AM
woops.. sorry Quik Sol.. thought i had pmed you already.
Old Mar 8, 2004 | 04:03 PM
Ryan C's Avatar
are those stock sleeves?
Old Mar 13, 2004 | 07:23 AM
36Chambers's Avatar
How bout this for a B18c5
3. Eagle Rods
with 9:1
Old Mar 15, 2004 | 10:54 PM
Default Re: (TypeR690)
woops sorry if I havent posted back on this thread. been PMing all replies.
any questions send them this way.
Old Oct 7, 2009 | 11:25 AM
got dell's Avatar
Default Re: TURBO RACE BLOCKS: Custom built by EXOSPEED Race Engines
Bump!!!!!!!!!!!!!!!for EXOSPEED
Old Oct 25, 2009 | 09:26 PM
mrbh22's Avatar
did u really just bump a thread from 2004?
cmon man.
Old Oct 25, 2009 | 09:49 PM
IT'S ME DAVID's Avatar
NooB
pimp builds and work
Old Apr 30, 2011 | 06:39 AM
vin2911's Avatar
Hi there...do you do a non terbo engine ,i am looking for a B16A Engine block using a 1.8 crank and 1.8 rod ,can any one do the custom piston for this set up ...do adv piston size 86mm.
Old Apr 30, 2011 | 01:56 PM
BoOstRetarD69's Avatar
cmon man.
lmao! RIGHT
Old Apr 30, 2011 | 11:11 PM
vin2911's Avatar
No may be any one can help me to get this custom piston
coquieg6
13
Aug 26, 2009 11:06 AM
aleks77
Feb 10, 2007 06:39 PM
7rrivera7
Jan 12, 2007 02:49 PM
ExospeedAMcrx
Jul 20, 2005 11:55 AM
ExospeedAMcrx
Feb 24, 2004 11:26 PM
