best cams to run for h22 going n/a
Old Feb 24, 2004 | 09:50 PM
Single MOBB's Avatar
Default best cams to run for h22 going n/a
like the topic says best cams for h22 going n/a. want to know what people are using and what they think about their cams.
Old Feb 24, 2004 | 10:19 PM
BlckBeautyVTEC's Avatar
Default Re: best cams to run for h22 going n/a (ALLGo NOShow)
friend has skunk 2 its in the process of being installed so well see after he gets it done and tuned
Old Feb 24, 2004 | 10:23 PM
Spartanic's Avatar
Definitly check out the Skunk2's or the OEM Type S camshafts. Check it all out at http://www.jdmgears.com.
Old Feb 24, 2004 | 10:43 PM
aeolus's Avatar
Default Re: best cams to run for h22 going n/a (Spartanic)
crower stage 3's are nice
Old Feb 25, 2004 | 04:59 AM
LudeHatchH22a's Avatar
why dont you compare the skunk2 stage2 to the crower stage 3s, because the skunk2 has 505 intake and 465 exhaust. Im sure the crower isnt as good on intake. If i had to buy cams again, i think id get teh skunk2 stage 3 cams, but then again i can live with a lumpy idle.
But Skunk2 is my choice!!!
I personally have the skunk2 stage2, and im very happpy with them.
Old Feb 25, 2004 | 07:14 AM
Daboi630's Avatar
Default Re: best cams to run for h22 going n/a (aeolus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">crower stage 3's are nice </TD></TR></TABLE>
werd!
check out the facts in my sig
Old Feb 25, 2004 | 07:28 AM
thehondaguru's Avatar
Default Re: best cams to run for h22 going n/a (Daboi630)
I have heard nothin but good stuff about the crower stage 3's
Now I wish I bought the 3's instead of the 2's. Anyone want to trade?
https://honda-tech.com/zerothread?id=779324
Old Feb 25, 2004 | 07:58 AM
speedracer9k's Avatar
Default Re: best cams to run for h22 going n/a (BlckBeautyVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlckBeautyVTEC &raquo;</TD></TR><TR><TD CLASS="quote">friend has skunk 2 its in the process of being installed so well see after he gets it done and tuned</TD></TR></TABLE>
hey, the guy never showed up to help me finnish the project, i can't even get into touch with him. i can't wait to try out the skunk2 stage 2's. i also have the valve springs, retainers, cam gears, and VTEC controller, with FPR, 9lb. flywheel, and a clutch specialties stage 2 clutch. i'm hoping for some power out of it.
Old Feb 25, 2004 | 09:10 AM
94vtecmn's Avatar
Default Re: best cams to run for h22 going n/a (speedracer9k)
I like my Crower Stage 2's, noticable power gains from 3500 up, with a peak of nearly 20whp.
Old Feb 25, 2004 | 09:15 AM
Daboi630's Avatar
Default Re: best cams to run for h22 going n/a (94vtecmn)
hmmm yeah i think crower cams are my next mod
have a dyno of your setup 94vtecmn?
Old Feb 25, 2004 | 10:24 AM
94vtecmn's Avatar
Not one I can post, but I did dyno at 195whp. Do you need a list of other mods?
BTW, I am one getting a SMSP header w/Cat, and I will be dyno tuning that, so hopefully I will have a postable graph then.
Old Feb 25, 2004 | 10:30 AM
Daboi630's Avatar
im just trying to build the Dyno Page with various setups. but DEFINETLY get the dyno with your SMSP header. its the dyno chart we have been waitin for
Old Feb 25, 2004 | 10:43 AM
WRS Motorsports's Avatar
JUN or RS Machine cams make more power than the Skunk2's or the crowers, if tuned right.
Old Feb 25, 2004 | 12:08 PM
Default Re: best cams to run for h22 going n/a (WRS Motorsports)
your right but you pay for that extra power
Old Feb 25, 2004 | 12:24 PM
DxTrix's Avatar
Default Re: best cams to run for h22 going n/a (95 lude)
Jun cams
Old Feb 25, 2004 | 12:32 PM
2point2's Avatar
Dynos with crower stage 3's are making me think twice about going turbo..
Old Feb 25, 2004 | 01:09 PM
One Slow Lude's Avatar
what is the diff in stage three and stage 2 crowers....beside the obvious of more lift and aggresive lobes, i mean are they for all out race aplications or are they good for the street too? do they idle ok still?
i wanted to get stage 2's as my next mod....but if the stage 3 are much better without having to rebiuld to suit them or anything... i mean i know i'll be needing better spring and retainers....
Old Feb 25, 2004 | 01:14 PM
satan_srv's Avatar
Default Re: (One Slow Lude)
look on crower's website.
I would go crower 3. I firmly believe the Skunk2 Stage 2 is too aggressive of a cam for a street motor. I have yet to see a skunk2 S2 dyno that makes good midrange power. It's a straight out race cam.
Old Feb 25, 2004 | 01:17 PM
Default Re: (satan_srv)
so crower 3 is ok for street also then?
they say all motor drag on the web site, which is why i am asking if they are ok for the street...... or does power only come on real high in the rpm
Old Feb 25, 2004 | 01:18 PM
Soda Popinski's Avatar
I think skunk stg 2s on the contrary would work fine on a street motor. Just need a good tuner to make sure it idles fine. Just becareful and dont run the skunk oversized vlaves with them because the lift is so tremendous, you might have clearence issues.
Old Feb 25, 2004 | 01:22 PM
satan_srv's Avatar
Default Re: (BeeBeeOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeeBeeOne &raquo;</TD></TR><TR><TD CLASS="quote">I think skunk stg 2s on the contrary would work fine on a street motor. Just need a good tuner to make sure it idles fine. Just becareful and dont run the skunk oversized vlaves with them because the lift is so tremendous, you might have clearence issues.</TD></TR></TABLE>
Again, I have yet to see any good dynos.
Old Feb 25, 2004 | 01:25 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Slow Lude &raquo;</TD></TR><TR><TD CLASS="quote">so crower 3 is ok for street also then?
they say all motor drag on the web site, which is why i am asking if they are ok for the street...... or does power only come on real high in the rpm </TD></TR></TABLE>
I've been running crower 3's for 2 years on the street. They have heavily modified non-vtec lobes so it makes power everywhere when tuned. Higher compression is a must. Idle is at 1100. Seems streeable enough for me. Here is my old dyno, realize that the car is heavilymodified and stll runs a cat and other street stuff.
Joel
Old Feb 25, 2004 | 01:31 PM
so you had to raise the compression?
do you have to with the stage 2's cause i didnt want to touch the bottom end...but hey if i gotta to make some power , you got good numbers with them though, damn.... i would def be happy with that
Old Feb 25, 2004 | 01:34 PM
I would say you would have alot of tuning and idle prob's without raising the compression.
Old Feb 25, 2004 | 01:36 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by One Slow Lude &raquo;</TD></TR><TR><TD CLASS="quote">so you had to raise the compression?
do you have to with the stage 2's cause i didnt want to touch the bottom end...but hey if i gotta to make some power , you got good numbers with them though, damn.... i would def be happy with that</TD></TR></TABLE>
compression is 11.9:1 or so, you don't have to raise compression..but you'll make more power if you do, and generally have less idle issues.
10:1 with a lumpy non-vtec cam would probably not idle so good. That's why a lot of people buy a stage 2 cam which has un-modified non-vtec loves and cam profiles to matchwith lower comp numbers.
