****MOTOR HELP ***
Old Feb 24, 2004 | 09:13 PM
Mr HYDE's Avatar
Default ****MOTOR HELP ***
got some questions for everyone. friend is doin a ls swap in to his 90 4 door civic. he has both 1990 4 door civic dx and a junk 1992 integra ls which he is swaping teg parts onto the civic. first question. will the mounts work from his b18 on to the civic? and wireing question can he take the dx wireing harness and swap it on to the ls motor?
Old Feb 24, 2004 | 09:18 PM
ThatRicerDaniel's Avatar
Default Re: ****MOTOR HELP *** (gen5hatch)
no and no .. he will need to use the rear motor mount from the integ and you will have to get a after market mount kit to make the motor fit and no you can use the dx harness because its only DPFI .. you will need to get a SI harness or the teg harness should work with a few mods .. you will also need to convert the civic to MPFI. good luck
Old Feb 24, 2004 | 09:31 PM
Mr HYDE's Avatar
Default Re: ****MOTOR HELP *** (NitrousDreamz)
**** i forgot about dual point and muti point, 88-91 si harness will work? he still has the wireing harness for the teg and he def needs a molnt kit? cuz i know for my swap gsr in to a 93 civic it was just useing the driver side mount for teh teg and civic mounts for the other 2
Old Feb 25, 2004 | 04:31 PM
Mr HYDE's Avatar
ttt both motors say pgm-f1 on the intake manifold
Old Feb 25, 2004 | 07:25 PM
yes he will for sure need the mount kit and he will for sure need the rear mount off the teg to make the mount kit work. after you do the MPFI swap you can either si or teg harness.
absinthminded
Aug 31, 2008 04:48 PM
rsdriver17
Oct 17, 2007 11:52 PM
fwdlooser93eg
Aug 14, 2006 01:59 PM
phatboi
Jan 7, 2005 03:21 AM
