h23: cams and cam gears
Old Feb 24, 2004 | 06:58 PM
teamlegacy's Avatar
Default h23: cams and cam gears
so yeah, searching didn't help me for **** so here i am!
so i'm researching some cams and cam gears for a hopeful h23 motor i'll be getting. it lacks the cams/gears and a few others that the aftermarket will provide me with. so ehre's my quesiton.
race-eng has a set of cam gears. it says for the b16/b18c/h23 motors. so does that mean the cam gears for those motors (also b18b if i'm not mistaken) are all the same?
also cams, crower sells only the dohc vtec cams and skunk2 the same way. anyone offer good streetable (not extreme) cams for the h23 engine?
intake manifolds. aebs makes them for the bseries, skunk2 doesn't have any for the h23. what other manifold will work. H22?
throttle body. i'll probably just get a stocker w/ a tps, but anyone recommend a good, close to stock priced throttle body? if you do, please let me in on the secret!
well, that's all for now. i really would appreciate any help that can be given. sorry for the questions, but nowhere gives me clear answers like honda-tech. thanks!
-colin
Old Feb 24, 2004 | 07:25 PM
teamlegacy's Avatar
Default Re: h23: cams and cam gears (teamlegacy)
forgot to add:
if i used an h23 transmission, could i use the starter from my f-series motor and be square?
what about injectors and the injector rail. are there peak/hold differences? would they be a suitable replacement?
i have an f22b2 from an accord lx by the way.
Old Feb 24, 2004 | 07:30 PM
str8rcn's Avatar
Gude makes cams for the H23 they are regrinds but i had a set for over 4 years with no problems. I dont think the cam gears are interchangable.
No manifolds that i know of maybe venom.
I dont know about the starter.
Old Feb 24, 2004 | 07:36 PM
teamlegacy's Avatar
Default Re: h23: cams and cam gears (str8rcn)
well from what i've read before the b18b cam gears and h23 cam gears are interchangeable. and i've never heard great stuff about gude, a lot probably heresay, but until i get hard evidence that they are good and/or bad, i'll stay away.
ive searched through the archives and found that webcams are pretty good, but their website just gives regrind prices, is that all they offer?
manifolds, yea i've got nothing. stock i guess will do, ohwell, aftermarket manifolds dont make that much power considering i'm not doing a huge build.
Old Feb 24, 2004 | 07:41 PM
satan_srv's Avatar
E-mail crower. Supposedly H23 cams are done.
Old Feb 24, 2004 | 07:44 PM
teamlegacy's Avatar
Default Re: h23: cams and cam gears (satan_srv)
that's what i've read. but does anyone have experience with them yet? i'd assume b.c they're so new, the prices are fairly steep.
Old Feb 24, 2004 | 07:58 PM
satan_srv's Avatar
i heard it was only going to be $400 for the pair.
Old Feb 24, 2004 | 11:02 PM
Hawkze_2.3's Avatar
Here is an e-mail response I recently got from Crower--
""Cams are available and just about to be released to the general public.
Similar listings as the LS (Stage 1, 2, 3, etc...) along with a spring and
retainer kit. Cost will be $400 for the pair and another $339 for
spring/retainer kit.
Thanks for your interest in Crower,
Crower Cams & Equipment Co, Inc
6180 Business Center Court
San Diego, CA 92154-5604 USA
Tel: 619-661-6477
Fax: 619-661-6466
http://www.crower.com""
Sounds good to me.....
Old Feb 24, 2004 | 11:06 PM
Hawkze_2.3's Avatar
Oh, and a new Honda throttle body is 500 bucks, about the same as a larger aftermarket one, you just don't get the TPS sensor. Luckily junkyards have many....
If you can afford it, I'd get the Unorthodox Racing cam gears just because I like their quality, and they give you reccomendations on how to set them....they're like 3-4 hundred bucks though, whereas Skunk 2's are also good, but only about 200....
Old Feb 25, 2004 | 12:19 AM
@ries's Avatar
B-series cam gears are inter-changeable. If you're still looking for a good throttle-body... I'd suggest the JG/Edelbrock and as for the intake manifold... I'd just port the stock intake mani.
Old Feb 25, 2004 | 03:59 AM
teamlegacy's Avatar
Default Re: h23: cams and cam gears (emoBB1)
would i really need to get an aftermarket throttle body and a ported manifold. im not doing a crazy build. probably just pulleys, cam/gears, intake, header, exhaust. also my 190lph fuel pump and probably a FPR.
thanks about crower, i'll check that out!
Old Feb 25, 2004 | 02:31 PM
@ries's Avatar
No.. if that's all the mods you plan on doing. If you were to get cams also then I'd get a TB and just match-port it the intake mani.
Old Feb 25, 2004 | 02:57 PM
teamlegacy's Avatar
yeah i figure just get a stock manifold and tb and port those. meh?
Dabrybry
Oct 21, 2008 02:21 PM
turbolude92
Mar 3, 2004 07:07 PM
tintin11
Mar 18, 2003 08:10 AM
