what wastegate/turbo for sohc!!!!?
Old Feb 24, 2004 | 05:32 PM
JdM_Eg_6's Avatar
Default what wastegate/turbo for sohc!!!!?
I need help on figuring out what wastegate i will need that will work on my d16z6 motor. I am looking to get close to 300 whp out of my motor and i need to know what wastegate and turbo that would be good to get for it? THanks!!!!!
Old Feb 25, 2004 | 01:34 PM
JdM_Eg_6's Avatar
Default Re: what wastegate/turbo for sohc!!!!? (JdM_Eg_6)
ttt!
Old Feb 25, 2004 | 01:43 PM
TravSi's Avatar
Tial 38mm will be perfect.....For 300hp i would say t3 60 or super 60 with .63 turbine will get you there cause its what im using to get me there, read my post for "noobs and anyone interested in turbos", I put down some good links to read and look at compressor maps and see which might do best for you, Also read this article of fueling cause im sure that question will arise also, it will help figure out pump, injector, fuel pressure etc....good info, and read those other articles as well....I researched to figure out what i needed to buy so I suggest the same but I gave ya an idea of what to use now its up to you to decide which will work best, Good luck
http://www.aempower.com/faq.asp?sid=15
Old Feb 25, 2004 | 04:06 PM
JdM_Eg_6's Avatar
Default Re: what wastegate/turbo for sohc!!!!? (TravSi)
thanks a lot for the post!
ktran1
Jul 13, 2006 01:01 AM
dohdoh420
Nov 7, 2005 08:33 PM
HONDA KID
Apr 24, 2005 01:22 PM
green91
Jul 22, 2004 12:30 PM
dmak
Mar 18, 2003 10:15 PM
