ingalls extreme camber kit
Old Feb 24, 2004 | 04:35 PM
lsvtec_DA's Avatar
Default ingalls extreme camber kit
Any have one of these on there integra? Where did you buy it from and how much negative camber can it correct? I am lowered about 3 inches and need something for my camber problem.
Anyone have a good online source that sells ingalls kits??
Old Feb 24, 2004 | 05:15 PM
98-sil.teg.'s Avatar
Default Re: ingalls extreme camber kit (lsvtec_DA)
For my rear chamber kit I have the Ingalls kit that has a shaft and two pivot points at the end, and it worked great for me, although I only have about a 2" drop. Im pretty sure that, that one will do about any though.
This isn't the actual ingalls kit but it looks similar to it.
Old Feb 24, 2004 | 05:29 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I wouldn't use replacement upper control arm bolts to correct alot of camber, as the upper control arm tends to hit the seam up in the fenderwell. However you can probably get by with a regular camber kit, the kind that corrects 1 degree or so. I am also lowered 3" and my front camber is around -2.5. You could take away -1 degree and run around -1.5 camber in front and have NO tire wear problems. You don't want the camber to be 0 because it will make handling worse. -1.5 is a good number to retain good handling and still have even tire wear. Just make sure the toe is set to factory specs and rotate your tires every 3K-5K miles.
Old Feb 24, 2004 | 05:50 PM
91integraLSVTEC's Avatar
Default Re: ingalls extreme camber kit (PatrickGSR94)
i have the extreme polyutherane camber kit on my DA. give my ride a soild feeling, my rear is set perfectly, my front is a little off. if you do get the poly make sure u lube the **** outta them!!! i got mine from here
http://www.iapdirect.com/default.asp
Old Feb 25, 2004 | 08:41 PM
cu3tip's Avatar
skunk2!!
Old Feb 25, 2004 | 09:59 PM
Spartanic's Avatar
Default Re: (cu3tip)
Check out Ingalls and Skunk2's camber kits at http://www.jdmgears.com.
BJA86
11
Sep 2, 2007 01:00 PM
b18LS
Suspension & Brakes
Apr 18, 2007 06:05 AM
GroundZer0 336
Sep 2, 2004 09:25 PM
KanzenR95GSR
Apr 22, 2004 01:21 PM
iam7head
Sep 11, 2002 11:05 PM
