quik question about neuspeed springs
Old Feb 24, 2004 | 01:55 PM
7808's Avatar
Default quik question about neuspeed springs
do i need a camber kit with neuspeed race springs? (96 prelude)
do stock shocks work fine with them?
if i need a camber kit its only for the front right?
can i fit, say, 18x7's with 40 or 35 series tires on them with these springs?
neuspeed race springs: 2.25" drop in front, 2" in back
thanks
Old Feb 24, 2004 | 03:29 PM
Jeff99Base's Avatar
Default Re: quik question about neuspeed springs (fuctup)
Chances are you will need a camber kit, unless you want to chew through tires. I have heard of people getting away with about a 1.5 inch drop max without needing one and even then its cutting it close. With the Race springs you will most def need one. Chances are you will need both a front and rear camber kit, but the best bet is to take it somewhere once you drop it, get an alignment and go from there.
Stock shocks will technically work, but I would upgrade them to help dampen the higher spring rate of the neuspeed springs. The stock shocks will work for awhile, but eventually they will die due to the fact that they are trying to dampen shocks that are stiffer than stock.
I dont know about clearing 18's. I would guess you could clear them but I wouldnt trust me on this one, I have a 5th Gen not a 4th so it might be better to find someone with this setup and ask them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">do i need a camber kit with neuspeed race springs? (96 prelude)
thanks</TD></TR></TABLE>
Old Feb 25, 2004 | 04:12 AM
7808's Avatar
Default Re: quik question about neuspeed springs (Jeff99Base)
bump for and one with a 4g that5 knows
civic_driver
39
Sep 29, 2005 07:54 PM
MSP
Mar 29, 2005 09:33 AM
enufspace
Jun 11, 2002 02:24 PM
Aaron M
May 6, 2002 05:39 AM
