b16 mods!!!!!!!!
Old Feb 24, 2004 | 10:09 AM
jsteezy1290's Avatar
Default b16 mods!!!!!!!!
i just bought a b16a for my 1989 si crx and i want to buy some mods for it but when i tried to get a dc 4-1 header they said they dont make it for the crx i mean i know they dont but what car do i tell them i want it for?/?? a delsol vtec???
Old Feb 24, 2004 | 10:11 AM
ironchef25's Avatar
Default Re: b16 mods!!!!!!!! (jsteezy1290)
i dont think it will fit properly if your using your stock crossmember.
and also your gonna have to take it somewhere to weld another bung for the other o2 sensor.
Old Feb 24, 2004 | 10:15 AM
crxirex's Avatar
Default Re:
I have ordered all my bolt-on's from a 95 del sol 1.6 dohc vtec. There are many options to a b16a engine. Do a search! .
Anyways, it might hit the crossmember depending on what mounts you used. If so just take a noch out, chance's are you will not have to take that much out. other wise go out and buy a jimfab or a z10 setup, much worth the money spent. Than agian that may not even fix the problem. depends on the mounts you used!
Old Feb 24, 2004 | 10:18 AM
ironchef25's Avatar
Default Re: Re: (crxirex)
well i have hasport mounts. will that fit?
Old Feb 24, 2004 | 10:22 AM
Hybrid Invasion's Avatar
Default Re: b16 mods!!!!!!!! (ironchef25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">i dont think it will fit properly if your using your stock crossmember.
and also your gonna have to take it somewhere to weld another bung for the other o2 sensor.</TD></TR></TABLE>only if you're using the stock ecu. If your ecu is chipped, it disables the second o2 sensor, therefore eliminating the need to have a second o2. My pr3 is chipped, I only have one o2 hooked up, I don't throw any codes, and my b16 runs fine.
Also, you can make a 4-1 header fit, but you have to cut the crossmember; something I don't recommend doing. Something about weakening the structural integrity of a front crossmember that turns me away from that idea. I would go with either a JimFab or a Z10 crossmember so that you can fit a 4-1 header without any cutting.
Old Feb 24, 2004 | 10:30 AM
manson's Avatar
Default Re: b16 mods!!!!!!!! (Hybrid Invasion)
you don't have to actually cut the cross member. there is a lip on the end of the cross member that you bend in order to fit the header in. i don't think bending away 3-4 inches of metal will structurally hurt you that much...other wise nobody would do it.
delsol vtec is what i order all my motor parts for.
Old Feb 24, 2004 | 10:54 AM
ironchef25's Avatar
Default Re: b16 mods!!!!!!!! (mansonclubpuir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mansonclubpuir &raquo;</TD></TR><TR><TD CLASS="quote">delsol vtec is what i order all my motor parts for.</TD></TR></TABLE>
do does that mean that say i get cam gears. cams. intake.
i should ask for a delsol vtec?
Old Feb 24, 2004 | 11:00 AM
FATshlong's Avatar
yes
Old Feb 24, 2004 | 11:05 AM
EL Vap133's Avatar
i should ask for a delsol vtec?</TD></TR></TABLE>
Not exactly, cams and cam gears are interchangeable with all B-series vtec motors. Hell I used cam gears that were on my LS teg motor on my B16a.....
Old Feb 24, 2004 | 11:24 AM
ICeDoUt's Avatar
You better watch yourself when doing this. I ordered a water pump and a bunch of other stuff for a 95 del sol DOHC vtec, that didn't fit my JDM b16. I used the b17 92 gsr to order most of my parts, and that worked for me.
Old Feb 24, 2004 | 11:26 AM
so if i bend the crossmember metal i can use a 4-1 header that is for a delsol vtec?
Old Feb 24, 2004 | 11:29 AM
EL Vap133's Avatar
Default Re: b16 mods!!!!!!!! (ICeDoUt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">
You better watch yourself when doing this. I ordered a water pump and a bunch of other stuff for a 95 del sol DOHC vtec, that didn't fit my JDM b16. I used the b17 92 gsr to order most of my parts, and that worked for me.</TD></TR></TABLE>
I used a water pump and timing belt ordered for a DOHC Del Sol B16a and it fit my JDM B16..... Which were the parts that didn't fit your ride?
Old Feb 24, 2004 | 11:30 AM
HamiltonRex's Avatar
SEARCH MAN!
-Eric
Old Feb 24, 2004 | 11:46 AM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: b16 mods!!!!!!!! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
I used a water pump and timing belt ordered for a DOHC Del Sol B16a and it fit my JDM B16.....</TD></TR></TABLE>
So did I, no problems
Old Feb 24, 2004 | 11:53 AM
crxirex's Avatar
Default Re:
lol, yeah, you won't have 2 o2's anymore, so your car will run like crap . You need to do and obd-1 conversion. Or if you know someone that can properly weld to bungs in the right place on the headers you could try that.
I haven't had any problems wit 95 del sol vtec parts for a 1.6 doch vtec But like I said before many parts will fit.
Old Feb 24, 2004 | 12:47 PM
germanEE8's Avatar
Do yourself a favor and get the 2 o2 bungs welded in there. I did it too!
Also I've got no clearance issues.... There is a lot of space to the crossmember.
And it comes no deeper than the oil pan!
greetz
marc
Old Feb 24, 2004 | 12:48 PM
ironchef25's Avatar
Default Re: Re: (germanEE8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by germanEE8 &raquo;</TD></TR><TR><TD CLASS="quote">Do yourself a favor and get the 2 o2 bungs welded in there. I did it too!
what headers are those?
Old Feb 24, 2004 | 12:53 PM
crxtreme89h's Avatar
Looks like DC Sports to me.
Old Feb 24, 2004 | 12:55 PM
ok im confused just tell me what vehicle i tell them i have if i want a waterpump timing belt and 4-1 headers
Old Feb 24, 2004 | 01:30 PM
germanEE8's Avatar
Default Re: Re: (jsteezy1290)
Its a DC Sports 4-2-1 ceramic coat.
The header is designed for del sol vtec and civic si 99-00.
Will fit EF8 without any modification.Just weld the 2 o2 bungs on and
put a screw in the bung at the end of the header near cat.
greetz
marc
Old Feb 24, 2004 | 01:45 PM
ironchef25's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by germanEE8 &raquo;</TD></TR><TR><TD CLASS="quote">Its a DC Sports 4-2-1 ceramic coat.
greetz
marc</TD></TR></TABLE>
do they sell that headers with the 2o2 on it already?
Old Feb 24, 2004 | 03:15 PM
crxirex's Avatar
Default Re:
just say you want parts for a 95 del sol DOHC VTEC 1.6L. The parts should be right!
Maintenance Items:
Gaskets Head gasket = US '94+ DelSol VTEC
Valve cover gasket = US '94+ DelSol VTEC
Spark plug O-ring gaskets = US '94+ DelSol VTEC
Intake manifold gasket = US '94+ DelSol VTEC
Exhaust manifold gasket = US '90-7 Integra or US '94+ DelSol VTEC
Spark Plugs = Any US B series motor
Cap and Rotor = US '90 Integra
Spark Plug Wires = Any US B series
Thermostat = US '90-1 Integra, US '94+ DelSol VTEC, '99+ Civic Si
Timing Belt = US '94+ DelSol VTEC
Water Pump = US '94+ DelSol VTEC
Lower Radiator Hose = '91 Integra
Upper Radiator Hose = Universal, may need trimming
Alternator = '90 Integra
Oil Pan = Any US B series
Oil Pump = 94 DelSol VTEC
Crank Pulley = Any US B series
Clutch = US '92 Integra GSR
Pressure Plate = US '92 Integra GSR
Pilot Bearing = Any US Civic/Integra
Throw-out Bearing = US '91-2 Integra, P/N 22810-ps1-015 $47.05
Flywheel = Any US B series
Axles = http://www.raxles.com, can use others, but best solution.
Intermediate Shaft = US '94+ DelSol VTEC
Mounts = http://www.hasport.com
Shift Linkages = http://www.hasport.com
Headers = best to use JDM B16
If this list helps any, I don't know. The list is pretty old, and I did not make it. But if it helps good luck!! If I have time I will make up a new list.
Old Feb 24, 2004 | 04:10 PM
Wicked_CRX's Avatar
I have a del sol one on my Rex... it hangs a little low depending on your motor swap.
Old Feb 24, 2004 | 04:38 PM
silverCRXTC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxirex &raquo;</TD></TR><TR><TD CLASS="quote">just say you want parts for a 95 del sol DOHC VTEC 1.6L. The parts should be right!
Maintenance Items:
If this list helps any, I don't know. The list is pretty old, and I did not make it. But if it helps good luck!! If I have time I will make up a new list.</TD></TR></TABLE>
I believe an ls oil pan will not work on a b16a
Old Feb 24, 2004 | 06:04 PM
Default Re: Re: (silverCRXTC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverCRXTC &raquo;</TD></TR><TR><TD CLASS="quote">
I believe an ls oil pan will not work on a b16a</TD></TR></TABLE>
Why is that?
Arent they physcially the same size? Just the LS is a taller block?
-Eric
