Holy F'n power window problems!!!!!
I can roll the passenger side window down from the drivers side but cant get it up.
Haha up.
Anyway, it will roll up using the passenger side switch with no problems.
I already changed the drivers side switch but no luck. 40 dollars later at te junk yard
Haha up.
Possibly your channels may need re-aligning or you may have this problem:
http://www.geocities.com/mugen...l.htm
Worse case scenario.
It may also be as simple spraying some silicone lube into the tracks to renew the rubber linings that mya have dried out.
I was also going to suggest get the relay checked, but you said you already replaced it. Might be the motor going out as well
He said he replaced the switch, not the relay.
If I'm not mistaken, there is a window control relay thingy bolted to the door, about 6-8 inches below controls.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greyout »</TD></TR><TR><TD CLASS="quote">He said he replaced the switch, not the relay.
If I'm not mistaken, there is a window control relay thingy bolted to the door, about 6-8 inches below controls.</TD></TR></TABLE>
Really I will have to look when I get home in a week.
Like I said before it goes up perfect from the passenger side. So I know it doesnt need aligned or lubed
I just took my spare doors apart the other day because someone needed the window motor. Unfortunately, I think I threw the relay away.
I have another pair of complete doors, but the cars in storage...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 »</TD></TR><TR><TD CLASS="quote">cool. glad someone asked this question bc my driver side rolls up the passenger really slow.
interested in seeing what works.
I will let you know!
</TD></TR></TABLE>I will let you know!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup »</TD></TR><TR><TD CLASS="quote">mine go up really slow - really really slow when its cold, and they make F'ed up sqeeking noise.. what kinda silicon spray is used on this and where all do you spray it?</TD></TR></TABLE>
If you go to auto zone or something like that just ask the guy at the desk for silicon spray and he will show you. Any brand will work. Also you could take your door oanels off and lube the components in there with some grease
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daboi630 »</TD></TR><TR><TD CLASS="quote">Thanks 95 lude.........
Greyout
as a seller</TD></TR></TABLE>
No prob man I am here for you!!!!
Greyout
as a seller</TD></TR></TABLE>No prob man I am here for you!!!!
dwardo55
Nov 20, 2012 07:45 AM
steven975
Honda S2000
May 3, 2004 04:37 PM
