OEM Exhaust Fit??
I ran a search and only found info on this regarding oem itr exhausts.
I have a 95 2dr integra with a lsvtec(b18a block and b18c1 head) in it. I have the stock gsr exhaust manifold, test pipe and apexi n1 exhaust.
my car is for sale, and a guy that looked at it and seemed interested in the car. He mentioned that he would take the exhaust of becuase he doesn't care for it. I am wanting to help him out and just replace the exhaust for him with an OEM exhaust.
The question is, will any 2dr integra(94 and up) cat and full exhaust fit onto my car, or will I need to get specificaly a gsr oem cat and exhaust?
How much should I expect to pay for used cat and exhaust, and how much do you think I could get for the catback n1 I have on there now?
im pretty sure your guna need a GSR exhaust since your runnin a GSR header. the GSR header is shorter than then LS/type R header, so that means the exhaust is longer. so u will need a GSR exhaust.
thanks for the help, just want to verify with others that above statement is true.
majority typically rules unless the majority rides the short bus
thank you
thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by __37__ »</TD></TR><TR><TD CLASS="quote">i had someone offer up a 2000 gsr exhaust and cat.
would a 2000 gsr exhaust and cat work or would only 94-99</TD></TR></TABLE>
A 00 GSR exhaust and cat are the same size as a 94-01 LS/97-01 ITR
