Fuel Pressure Regulator
Old Feb 24, 2004 | 06:30 AM
sparkso's Avatar
Default Fuel Pressure Regulator
HI All,
I have fitted a fuel pressure regulator into my DC-2 lately and I noticed the following three things:
1. I get a higher idle than before. Around 1100 rpm (before it was 900rpm)
2. Vtec has became less obvious, but I can still reach 8700rpms
3. Car seems to be more noisy than before.
Are these symptoms normal after fitting in a VRS fuel pressure regulator?
Thanks.
btw, how do i change the pressure of the regulator?
Old Feb 24, 2004 | 06:37 AM
96_GSR's Avatar
Default Re: Fuel Pressure Regulator (sparkso)
Get it tuned on a dyno with a wideband O2 sensor...
Old Feb 24, 2004 | 06:38 AM
TurboedGSR's Avatar
the symptoms may be normal after changing the fuel pressure. do you have a gauge? whats your static pressure a 0 vacumm?
and why do you think you need to change your fuel pressure
rdssk8rcs1
Oct 2, 2010 07:41 AM
scatuli
Mar 22, 2004 07:32 PM
_jester_
Aug 10, 2003 10:26 AM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
