Cracked LS turbo manifold.
Just some pics of me prepping up a Turbo mani to fix some cracks caused by MIG welding cast iron.
Long crack with dimple hole
multiple cracks and someone's Fucked up mig welding trying to hide cracks. not helping the situation.
Another picture where you can see they were trying to cover cracks with some kind of epoxy. maybe JB weld. that kinda smear look at the bottom of the pic
cut channel to try and get the brass down in their.
its been brazed up, will get you some finish pics later.
true about the drilling, it was done afterward this stuff, i was brazing and didn't think it wouldwork but i did it anyway, it turned out fine. finished pics will be posted around 5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote">true about the drilling, it was done afterward this stuff, i was brazing and didn't think it wouldwork but i did it anyway, it turned out fine. finished pics will be posted around 5</TD></TR></TABLE>
Can't wait!
Can't wait!
Did you need to preheat that to get a good weld? Or, is it just the ductile cast iron that you have to do that with?
Edit: Nevermind. That was a dumb question.
Modified by IN VTEC at 7:08 PM 2/24/2004
its a cast iron manifold. yes you do have to preheat the entire manifold before you begin. the best way to do this is put it in the oven at like 350 or 400 degrees for an hour or so. i have seen people use like propane weed burners, but it has to be a non-carbony gas so that you don't have to reprep the iron when its hot.
While brazing it i just used normal brass fluxed rod. Not the best choice, but the only option i had. One thing that is important is trying to get an nice feathery flame. You do not want an oxygen rich flame. make sure you cut nice trenches in the iron and that you drill small holes at either end of the crack to relieve the pressure of the cracks themselves. The thing that i do like about working with brass is that i am able to go a little heavy with the rod and still clean it up relatively nice.
You also need to insulate the manifold to prolong the cooling process, once you have finished welding. i just used some mulch and dirt and it was hot for several hours. your basic fiberglass insulation from a house will work well also. Several people bury the iron in lime, and it will stay hot for days. sand also works well.
If i could do it again, i would make much deeper trenches for brazing into, and i would have probably made a better effort to remove all of the previous mig weld which was in my way making the manifold look like ****. I would also have been more liberal with the heat before applying any braze, because once the braze is applied it is hard to reheat the metal without burning the braze. also, a stainless steel brush helps alot in prepping the surface where you will be welding. as you grind cast iron, you get alot of graphite type material that isn't going to allow for a good weld. just some info in a learning experience to spread to others. IF i had my choice, i would have tig welded with nickel rod, or oxygen acetalyne welded with nickel. and to all people modding cast iron for turbos or any reason, don't mig weld using normal mild steel wire, it works for a short period of time but then causes massive cracking, as what happened with this manifold. Then people try to fix the cracks with mig, causing even more problems.
Just trying to bring a little something back to life.
Modified by snoochtodanooch at 12:26 AM 2/26/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsbon »</TD></TR><TR><TD CLASS="quote">AHH TIME TO RAM THOSE CRX'S FROM MAPLE SHADE IN THE ***!!
(i didn't go to bed...
)</TD></TR></TABLE>
Maple Shade Rexs huh? hahahaha We will own them!
)</TD></TR></TABLE>Maple Shade Rexs huh? hahahaha We will own them!
Odiedogcx
Mar 21, 2006 06:11 AM
snoochtodanooch
Welding / Fabrication
May 19, 2005 02:52 PM
