City/Courtesy Lights
Old Feb 23, 2004 | 07:32 PM
JDubya's Avatar
Default City/Courtesy Lights
anyone have city (courtesy) lights in their USDM '94+ high beam housings? How does it look? I was thinkin about doing it when i take my lights apart paint them and to put some HID projectors in.
Old Feb 23, 2004 | 07:37 PM
BolivianDc2's Avatar
Default Re: City/Courtesy Lights (ALL MOTOR LS)
get these LED bulbs, i bet they would look nice at night http://www.superbrightleds.com/headlights.htm
Old Feb 24, 2004 | 07:42 AM
JDubya's Avatar
Default Re: City/Courtesy Lights (BolivianDc2)
hmm not bad. Does anyone have city lights in their teg?
Old Feb 24, 2004 | 08:16 AM
SuzukaBlueAP2's Avatar
I don't...but I just saw the city light sockets for sale and am giving it some though.....I think they would look cool.
Old Feb 24, 2004 | 08:17 AM
JDubya's Avatar
Default Re: City/Courtesy Lights (ScreaminTeg)
Where's the cheapest place to get the sockets from?
Old Feb 24, 2004 | 08:50 AM
pep boys sells them pretty cheap, any of thse stores like autozone, advance auto parts should have something there for cheap
Old Feb 24, 2004 | 09:05 AM
PepBoys sells OE Honda city light sockets ? why do I doubt that.
I'm sure they would work....but something tells me they just won't be the same...I dunno.
Old Feb 24, 2004 | 09:12 AM
integra's dont have city light sockets predrilled or anything, so custom work is required with or without OEM sockets, as long as the seal is good, then i wouldn't see a problem
Old Feb 24, 2004 | 09:57 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianDc2 &raquo;</TD></TR><TR><TD CLASS="quote">integra's dont have city light sockets predrilled or anything, so custom work is required with or without OEM sockets, as long as the seal is good, then i wouldn't see a problem</TD></TR></TABLE>
Exactly... You can purchase a DRL relay from Honda of Canada and there is two spots for fuses in the underdash fuse box... One spot for DRL relay, and one for the DRL themselves... It just turns on the highbeam bulb, but at a lower wattage... Can neone help me get a relay...?
Old Feb 24, 2004 | 10:05 AM
LSeeper's Avatar
Default Re: City/Courtesy Lights (4U2NV)
u mean like this? damn i jock this **** bad
Old Feb 24, 2004 | 10:08 AM
bub838's Avatar
isnt a pretty big pain in the *** to get DRL's in a usdm
Old Feb 24, 2004 | 10:14 AM
sinfulDB1's Avatar
Default Re: City/Courtesy Lights (LSeeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSeeper &raquo;</TD></TR><TR><TD CLASS="quote">u mean like this? damn i jock this **** bad
isnt that just a yellow high beam bulb.. and its on?? or no cause the fogs are on... idno?? i thought of getting a yellow high beam bulb but idno how bright it would be
Old Feb 24, 2004 | 10:20 AM
LSeeper's Avatar
Default Re: City/Courtesy Lights (ikendc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ikendc2 &raquo;</TD></TR><TR><TD CLASS="quote">
isnt that just a yellow high beam bulb.. and its on?? or no cause the fogs are on... idno?? i thought of getting a yellow high beam bulb but idno how bright it would be</TD></TR></TABLE>
Dats not high beam (that would be blinding and not healthy to other drivers on the road)...he did some kinda of conversion. BTW his low beam werent on...in our cases we would have to turn on the low beam in order to use the inner lights (high beam) too. PM Outkasted24, its his car
Old Feb 24, 2004 | 10:22 AM
4U2NV's Avatar
Default Re: (bub838)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bub838 &raquo;</TD></TR><TR><TD CLASS="quote">isnt a pretty big pain in the *** to get DRL's in a usdm</TD></TR></TABLE>
As far as I know it's just a relay that plugs in down by the dead pedal... Then the two fuses under the dash...
Old Feb 24, 2004 | 10:40 AM
IntEGNYC's Avatar
Default Re: (4U2NV)
even if you run it at a lower wattage, arent our headlamps fixed so that the high beams are proportionately pointed higher than the low beams?
just a thought/
Old Feb 24, 2004 | 10:45 AM
Default Re: (IntEGNYC)
Already knew that...just wondered how well the kits sold at Pep Boys were to fit into our headlights. i.e.....will they seal well ? how big of a hole must be drilled ? stuff like that. I actually think it's the same socket as our USDM sidemarker lights. They take the 194 bulbs i believe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">even if you run it at a lower wattage, arent our headlamps fixed so that the high beams are proportionately pointed higher than the low beams?
just a thought/</TD></TR></TABLE>
This is true. There are adjustments on the headlamp housings...but I don't know how much you would get out of them.
There are kits sold, that include a relay that hooks up to your ignition, or some ignition power supply, and they make the high beams run at half the wattage when you turn the key on. Just like most factory DRL kits.
I'll see if I can't find one online..
Old Feb 24, 2004 | 10:47 AM
4U2NV's Avatar
I'm not sure what your referring to...? Canadian Integras come stock with DRL... The only difference between theirs and ours is a relay and two fuses, as far as I know... The relay controls the wattage being sent to the DRL, cutting the highbeam wattage in half... When you turn on the headlights, the DRL's go off...
Old Feb 24, 2004 | 11:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
It doesn't matter, because the headlights are much dimmer and won't be blinding, even though they are aimed up. Also you can't adjust the high beams separately from the low beams.
I'm going to have to take my headlights apart again to fix my offcenter projector on the driver side, and I'll probably wire up some city lights. I'll probably just drill a hole in the bottom or top of the reflector and use some 194 sockets from AutoZone, and wire them up to the parking lights.
Old Feb 24, 2004 | 06:10 PM
JDubya's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
I'll probably just drill a hole in the bottom or top of the reflector and use some 194 sockets from AutoZone, and wire them up to the parking lights.</TD></TR></TABLE>
That's all I was gonna do. Where would the bulb look best (if it really even matters) top, bottom, or side of the housing?
Old Feb 24, 2004 | 06:28 PM
stp_vtec_boi's Avatar
Default Re: (ALL MOTOR LS)
hey um are these tha lights that flashs when u turn off ur car or something becux i seen some but never knew wat it was...
Old Feb 24, 2004 | 06:32 PM
Outkasted24's Avatar
Default Re: (stp_vtec_boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stp_vtec_boi &raquo;</TD></TR><TR><TD CLASS="quote">hey um are these tha lights that flashs when u turn off ur car or something becux i seen some but never knew wat it was...</TD></TR></TABLE>
Ahhh....No.
City lights are little 194 bulbs (sometimes colors) that sit in your housings (Mainly JDM except for the Newer year Preludes) and are often on during the day for a safety feature and can be used to make an Ion color to your factory light bulbs.
They are sat off to the side or bottom of a housing.
No blinking/flashing is involved.
Old Feb 24, 2004 | 06:35 PM
Default Re: (Outkasted24)
BTW: It's kind of weird to be scanning a site and come across a pic of your own car.
Heh
nice catch LSleeper
http://www.spwusa.com/ used to sell the real thing, All colors and harnesses
Check Em Out!
Modified by Outkasted24 at 10:47 PM 2/24/2004
CPreston
Lighting
May 21, 2009 11:35 AM
DinDinh04
Lighting
Feb 6, 2008 03:03 PM
Speedraca01
Jan 19, 2006 07:47 PM
b18c4door
May 20, 2005 10:41 AM
mr poo
Sep 16, 2003 08:39 PM
