4 point harness on stock seats.
Old Feb 23, 2004 | 04:41 PM
xmilanoredsix's Avatar
Default 4 point harness on stock seats.
Just wondering if anyone is running a 4 point harness on stock seats. Any opinions or comments on this setup would be very helpfull. Is installation hard, any modifications need to take place in order to mount. I was looking to get a driver side takata harness, using it either a sparco or Lokar motorsports harness bar.
Thanks
Old Feb 23, 2004 | 04:44 PM
Dropspeed's Avatar
Default Re: 4 point harness on stock seats. (xmilanoredsix)
Putting on flame suit.........................
You will soon see most here are very oppossed (with good reason) to installing harnesses with out a rollbar/cage unless this is for show.
Mattj
Old Feb 23, 2004 | 04:49 PM
Kendall's Avatar
Default Re: 4 point harness on stock seats. (Dropspeed)
Harnesses without rollbar
Seriously, research the safety issues associated with doing this.
Old Feb 23, 2004 | 04:57 PM
baonest's Avatar
Default Re: 4 point harness on stock seats. (Kendall)
spend
and get a cage
Old Feb 23, 2004 | 05:13 PM
Default Re: 4 point harness on stock seats. (baonest)
I wasnt aware that that was a problem with the harnesses. I could see how if it was floor mounted in the impact of an accident that the harness would pull down on the shoulders and compress the spine not to mention other problems. But with a harness bar mounted and installed properly what would be the safetly concern.
Maybe im just missing something,
btw thats a lot of money
Old Feb 23, 2004 | 05:18 PM
nightrider's Avatar
the safety concern would be that in an event of a rollover, you will be not move and your head could be crushed because there is no protection from the roof collapses. the stock 3 pt seatbelts however prevent this hazard by sliding you to the side in case of a rollover.
Old Feb 23, 2004 | 05:31 PM
Default Re: 4 point harness on stock seats. (nightrider)
Thank you nightrider, everything is crystal clear now.
Nick Azzarto
Dec 25, 2013 11:01 AM
Crazy_SI_T
Feb 19, 2013 08:54 PM
Stillo
Honda S2000
16
Feb 21, 2007 06:37 PM
ABTDer
36
Mar 17, 2004 10:34 AM
