Jdm pistons
To fit P73 (Integra Type R) pistons on LS rods, you need to shave each side of the rod by 1mm. However P30 (second gen B16A)pistons will fit the LS rods perfectly. And yes, they are the same bore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">To fit P73 (Integra Type R) pistons on LS rods, you need to shave each side of the rod by 1mm. However P30 (second gen B16A)pistons will fit the LS rods perfectly. And yes, they are the same bore.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">are an ls and type r of the same bore?? im looking to buy pistons, that would go on ls rods, is there any mods needed to be done to the rods??</TD></TR></TABLE>
yea the ls rods need to be milled 1mm on each side of the small end of the rod then shot peened for stress relieve and to replace the strength since you just scored off the rod to mate any "r" family of pistons to non r family rods u have to do that mod..althou JDM b16a SirII pistons mate directly on the ls rods with no modding..that is what i am doing here soon and i know of some people who have and they really like it.
Dont forget the shot peening.
i would go with pr3 pistons over itr's anyday
u dont really need to shoot peen the rods just make sure u get some arp rod bolts and resize the rods for the bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Yes, the PR3's will fit, as will the P30's. The P73's and the PCT's will require machine work. I'm not sure about the P72's, but I think they require machine work as well.</TD></TR></TABLE>
ok to just to be absolutely clear.... pr3's, the first gen b16 pistons, will fit with ease and give what compression??? p73 (itr's?) will require the shaving of the rod...?
Compression depends upon if you're using an LS head or one of the 2 different VTEC heads. Headgasket thickness will also have an effect, as will any milling of the head. From here, there's nothing I can tell you to do except search. I know this information has been covered in the past, all you have to do is find it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">Compression depends upon if you're using an LS head or one of the 2 different VTEC heads. Headgasket thickness will also have an effect, as will any milling of the head. From here, there's nothing I can tell you to do except search. I know this information has been covered in the past, all you have to do is find it.</TD></TR></TABLE>
thanks for your help! i know they fit, thats all i need!! u da man.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">resize the rod bolts? the rods and bolts arent changing, just the pistons..... ugh, confused</TD></TR></TABLE>
u have to resize the rods anytime u chage the rod bolts
and if your changing pistons i highly recoment u change the rod bolts to some arp rod bolts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">u have to resize the rods anytime u chage the rod bolts
and if your changing pistons i highly recoment u change the rod bolts to some arp rod bolts</TD></TR></TABLE>
shaweet, got em!!
shaweet, got em!!
boredracer408
Sep 17, 2008 06:13 PM
infamousALLMTR
Jun 3, 2003 03:33 PM
