power fc with a 3bar map???
Old Feb 23, 2004 | 01:42 PM
Dyno Queen's Avatar
Default power fc with a 3bar map???
How will i hook this up, im running a 95 gsr turbo with the apexi power fc, how will i wire the 3 bar map sensor in with the stand alone??
-Mike
Old Feb 23, 2004 | 01:54 PM
Dyno Queen's Avatar
Default Re: power fc with a 3bar map??? (lazerus)
cool man id appreciate it alot, i have not got my car running yet but im taking down this info, i want it to be reliable and not a problem so thanks again
-Mike
Old Feb 24, 2004 | 08:08 AM
Dyno Queen's Avatar
Default Re: power fc with a 3bar map??? (Dyno Queen)
up
Old Feb 26, 2004 | 05:50 AM
Dyno Queen's Avatar
help
Old Feb 26, 2004 | 06:13 AM
turbotypeR@SPEC's Avatar
25 Year Member
use the wiring diagram from hondata's web site.i will have to look to remember the setting on the fc or you can call xs engineering and they can tell you
Old Feb 26, 2004 | 06:38 AM
Dyno Queen's Avatar
Default Re: power fc with a 3bar map??? (turbotypeR)
ok man cool, are u running the FC datalogit also? did u get the software so that u can use the laptop or are u still using the commander?
Old Feb 26, 2004 | 07:27 PM
25 Year Member
using the commander
Old Feb 26, 2004 | 07:29 PM
Dyno Queen's Avatar
how hard is it to tune with it, ive heard the datalogit is like 400 bucks and it opens a ton more maps and features, not sure about that though. do u have any vids and pix of your car/setup
Old Feb 26, 2004 | 08:02 PM
25 Year Member
is easy to tune with.i had xs engineering do the base tune by a list of mods i gave them.you just send it in with your list of mods and they program it in.then when i got it back ,it was almost perfect.i spent two hours on the dyno and it was perfect.you can find pics and videos herehttp://meacham.pointclark.net/TurboTypeR/index.htm.they are kinda old and need to be updated.
Old Feb 27, 2004 | 07:27 AM
Dyno Queen's Avatar
awesome pix an vids man, when i get mine together i will let u kinda help out with the tuning, im gonna go ahead an volunteer you for a base map, how much was it to send yours to XS....?
Old Feb 27, 2004 | 08:57 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyno Queen &raquo;</TD></TR><TR><TD CLASS="quote">How will i hook this up, im running a 95 gsr turbo with the apexi power fc, how will i wire the 3 bar map sensor in with the stand alone??
-Mike</TD></TR></TABLE>
send a PM to "dmecarboy", he'll know...
Old Feb 28, 2004 | 03:59 PM
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyno Queen &raquo;</TD></TR><TR><TD CLASS="quote"> how much was it to send yours to XS....?</TD></TR></TABLE>
i think they charge $150
Old Feb 28, 2004 | 04:46 PM
alpha's Avatar
Have you looked through the Power FC to see what all the settings are yet? If not go ahead and start doing that. Keep us updated on your results with the Power FC
Old Feb 28, 2004 | 06:18 PM
MiraiZ's Avatar
I would use the Apexi 3BAR map sensor instead of the GM...it plugs right into the PFC ECU, and the you just change the map sensor to option 4 within the program.
its expensive, but there's less problems and its completely plug and play.
sorry for the huge pics....
Old Feb 29, 2004 | 07:51 AM
Dyno Queen's Avatar
Default Re: power fc with a 3bar map??? (MiraiZ)
pix didnt work for me, i tried to find apexi 3bar map, i couldnt find it anywhere, if u could link me there i would appreciate it, thanks alot
-Mike
Old Mar 1, 2004 | 06:33 AM
Dyno Queen's Avatar
oh and i also had another question, is there settings for boost levels? Say u want like 10-13 psi on the street, but u want 20-??? psi on the track can XS set it up like that im not familiar at all with the power fc....thanks alot
-Mike
Old Mar 1, 2004 | 10:50 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">I would use the Apexi 3BAR map sensor instead of the GM...it plugs right into the PFC ECU, and the you just change the map sensor to option 4 within the program.
how much $$$ are we talking about? I have the power fc...
Old Mar 1, 2004 | 12:34 PM
Dyno Queen's Avatar
i need a link to find this, i cant find one anywhere, thanks
Old Mar 1, 2004 | 12:52 PM
MiraiZ's Avatar
Default Re: (Dyno Queen)
costs like $180....yeah i know
Old Mar 1, 2004 | 12:57 PM
Dyno Queen's Avatar
Default Re: (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">costs like $180....yeah i know </TD></TR></TABLE>your don't know where i can find one?
Old Mar 1, 2004 | 09:35 PM
Dyno Queen's Avatar
found it on http://www.sportcarmotion.com for 80 for the map sensor, not sure if u have to buy the lil wiring with it?
Old Mar 2, 2004 | 02:07 AM
MiraiZ's Avatar
I bought mine from Top Fuel Mie, butI'm sure Apexi-USA carries them or can get one for you.
part #499-X001 for sensor
Modified by MiraiZ at 7:50 PM 3/3/2004
Old Mar 2, 2004 | 05:33 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyno Queen &raquo;</TD></TR><TR><TD CLASS="quote">found it on http://www.sportcarmotion.com for 80 for the map sensor, not sure if u have to buy the lil wiring with it?</TD></TR></TABLE>
Q: all you need is the wiring from the map sensor to the power fc right. Or are you talking about something different. I would think that it should come with it all but thats an ASSumption
Old Mar 2, 2004 | 06:07 AM
Dee's Avatar
Dee
Default Re: (4-banging)
The Apex map sensor is the same Nippon Denso sensor used by Integral gauges. I got mine for $150.
Old Mar 2, 2004 | 07:51 AM
4-banging's Avatar
Default Re: (Dee)
was this Apexi map sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee &raquo;</TD></TR><TR><TD CLASS="quote">The Apex map sensor is the same Nippon Denso sensor used by Integral gauges. I got mine for $150.</TD></TR></TABLE>
geeze...that seems quite expensive??
Are these already prepped for 3-bar? Is it in the wiring that makes it a 3-bar??
