For Those With Tein SS Coilovers
Old Feb 23, 2004 | 01:07 AM
SynTeg's Avatar
Default For Those With Tein SS Coilovers
I searched and seen that you guys used zip ties for your brake lines. I'm just wondering if anyone used the brake line bracket from the stock strut. And also which stock pieces did you use in addition to the Tein parts.
Old Feb 23, 2004 | 06:46 AM
typeRSXS's Avatar
from what i know, the only stock part you use is the black boot from the top of all the stock suspension. i forget what it was called, bleh, 7am, tired
Old Feb 23, 2004 | 07:04 AM
FlaN.'s Avatar
Default Re: (shupaGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shupaGSR &raquo;</TD></TR><TR><TD CLASS="quote">from what i know, the only stock part you use is the black boot from the top of all the stock suspension. i forget what it was called, bleh, 7am, tired</TD></TR></TABLE>
you're talking about the upper pillowball mounts. yes you can use those, and your stock brakeline bracket on your teins
Old Feb 23, 2004 | 07:09 AM
typeRSXS's Avatar
yep those thanks theJUMPoff, i couldnt think of it.
Old Feb 23, 2004 | 09:06 AM
purplegsr's Avatar
Yeah, I used the upper mounts, one washer that may not have been necessary, and the stock brake line brackets. As long as you match up the little indentation on the stock fork with the one on the bracket, it should work fine.
maxamman11
Suspension & Brakes
Mar 4, 2007 04:34 PM
LBBP R
Honda S2000
Jul 31, 2005 08:06 PM
SynTeg
Feb 9, 2004 05:55 AM
93EH6
Dec 13, 2003 03:36 PM
MugenPoweredLude
Feb 6, 2003 07:17 PM
