how can you tell if it is type s cams or not?
compare the min/max diameter on the vtec lobes to stock, type-s have more lift and a part number I'll have to look up...
PRELUDE BB-6 TYPE-S CAMSHAFT (IN) 14111-P5P-J00 <part numbers
PRELUDE BB-6 TYPE-S CAMSHAFT (EX) 14121-P5P-J00
Type-S cams have 12.2mm intake and 11.2 exhaust. This equates to .480" intake and .440" exhaust. The H22A S adopts high performance camshafts with more valve overlap and higher lifts as follows:
Valve timing*
Normal H22A, "S" H22A
Intake opening (BTDC)
15 15
Intake closing (ABDC)
40 45
Exhaust opening (BBDC)
40 45
Exhaust closing (ATDC)
15 15
Valve lift* Normal H22A, "S" H22A
Intake (mm)
11.5 12.2
Exhaust (mm)
10.5 11.2
*Honda's valve timing/lift are measured at 1-mm lift
There is help. now go and help yourself, get a micrometer and take some initiative. And use "type cam" for the search field in the archived posts on this page: https://honda-tech.com/zerosearch and you will find a bunch of posts concerning this same question...
the Pirate
Valve timing*
15 15
40 45
40 45
15 15
Intake (mm)
11.5 12.2
Exhaust (mm)
10.5 11.2
the Pirate
lil big iron 2
Jun 2, 2004 12:29 AM
