Too Old for Turbo?
Old Feb 22, 2004 | 09:55 AM
Catera's Avatar
Default Too Old for Turbo?
My 95 gsr has 105k miles on it. It's pretty well maintained; new timing belt, water pump, radiator. I would love to go turbo but I don't think the investment is worth it with such a high mileage engine. what do you think?
-steve
Old Feb 22, 2004 | 09:58 AM
Kendall's Avatar
Milage isn't as important as the overall condition of the engine. Give it a compression and leakdown test. If everything looks good, then go for it.
Old Feb 22, 2004 | 10:10 AM
gsrmike's Avatar
Yeah Kendall is right. Do all the tests you can. If your gonna go high boost I would resleeve the block and might as well do a whole engine overhaul while it's out but thats if you have big plans
Old Feb 22, 2004 | 10:14 AM
Mad Cow's Avatar
Default Re: Too Old for Turbo? (Catera)
Forced Induction questions are better asked in the Forced Induction forum. As previously stated, mileage means very little.
Compression test AND leakdown test would be the best way to go. Even if you get bad results, the cost of rebuilding your motor is minimal compared to the turbo kit assuming you rebuild yourself.
Old Feb 22, 2004 | 10:31 AM
Kendall's Avatar
Put it this way: If you have to rebuild the engine, then you can go ahead and build it for boost.
newtothescene
Apr 5, 2008 04:53 PM
balili89
Feb 18, 2008 10:14 AM
ggangtong81
Aug 12, 2005 07:50 AM
extra cam needed
Jun 30, 2005 07:26 PM
IntegraLs94Cam
Jun 5, 2004 10:45 PM
