Did a y8 head & manifold swap on a d16a6, which are the better injectors to use.
Well i was wondering if i should use the injectors that came with the y8 head and mani, or if i should use my A6 injectors. If anyone has any info please let me know, thanks.
Are you obd1? If you are, cut out the resistor box and connect all those wires together, then use teh obd1 injectors, obd2 it its from a y8, but im sure its all the same. If your not, you need to keep the resistor box and use teh a6 injectors.
iphatcrxi
Nov 14, 2006 10:09 AM
EJ2-Fluffy
11
Jan 13, 2005 03:01 PM
