Will an ITR Head bolt onto a 96 SE block?
Ive heard that you can bolt a gsr head onto the block of an LS/SE Integra. Is this true? Can you bolt an ITR head onto one as well? Also, how much would an ITR head cost from the factory? Anyone know?
Trench
Trench
What kind of horsepower will it give me then? Also, do you know how much a new ITR enigne would run me from the factory? GSR?
Trench
Trench
isn't the ITR head from Acura just a B16 head? the real ITR head is ported n polished by hand...which is not done if you buy it from the dealer, so get a used one...
(correct me if i'm wrong)
Looks like you have a typo there.. Its B18B/A which came in the LS. B18C from GSR and B18c5 from ITR. And actually even tough it fits on your ls block.. doent mean it bolts right on.... you still have to run an oil line. HP figures if you leave everything stock... probably around 150-160 if i'm guessing right.
The ITR head has a slight P&P but the real difference is in the drivetrain and the cams.
[Modified by CRX_VTEC, 6:53 AM 10/13/2001]
Trenck, look up "Mike K" on this board, he can help you he isthe one who supply's alot of this board ith OEM acura/honda parts, because he works for them
