How do i adjust the Koni yellows?
Old Feb 21, 2004 | 03:16 PM
Undercover_Skank's Avatar
Default How do i adjust the Koni yellows?
I have the koni yellows all around...how am i supposed to adjust them? there is a **** on it but its not that white one that comes with koni...its just a long black **** that is attatched to the shock. and anyone have info on adjusting the shocks?
Old Feb 21, 2004 | 03:18 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How do i adjust the Koni yellows? (Vietvicious)
there is a little tab on top of the shock rod, you have to use the Koni adjustment **** to turn it. Do NOT try to turn it with pliers because it WILL break off if you do. If you don't have the ****, you can get them from Koni for about $5 each I think. Each pair of shocks comes with one ****, so I have 2 of em (I keep one in the car and one in the house for a backup).
Old Feb 21, 2004 | 03:49 PM
chads99gsr's Avatar
adjust them stiffness r ride height? I have koni yellows all the way around also. they r fricken awsome! I took mine down and had them machined for more adjustablity. They rock
Old Feb 21, 2004 | 05:57 PM
Default Re: How do i adjust the Koni yellows? (chads99gsr)
i just want it to be smoothe for the streets and i want to know how im supposed to adjust them when i race...what are the settings?
poormanstyperb16
Suspension & Brakes
14
Oct 28, 2010 12:56 PM
trevorjohn88ef
Suspension & Brakes
12
Dec 14, 2008 06:11 AM
busakiller
Mar 3, 2004 04:02 AM
slimbo
Mar 1, 2003 09:28 PM
VTEC-DA
Dec 28, 2002 10:41 PM
