HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY??
Old Feb 21, 2004 | 10:26 AM
LOSERboy's Avatar
Default HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY??
I recently just bought my 94 gsr and everytime I open the sunroof it shakes and slides back really rough....I applied grease to the rails but it still does it... any suggestions???
tia
Old Feb 21, 2004 | 10:34 AM
jdmintegra1994's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (LOSERboy)
hehe, mine does that too...i don't think it's a big deal though. You roll it back once for like 2 seconds then you dont' worry 'bout it 'til you get outta the car...or it starts raining
Old Feb 21, 2004 | 11:02 AM
typeRSXS's Avatar
get some oem grease from acura, lube that ish up. worked for me.
Old Feb 21, 2004 | 11:31 AM
W.O.P.'s Avatar
Default Re: (shupaGSR)
mine does that too, even after acura lubed it up. they said you have to keep it closed for 24hrs after you do that. also my sunroof sticks sometimes and i need to bump it to get it goin, does anyone have that problem too?
Old Feb 21, 2004 | 11:37 AM
lke2drvgsr's Avatar
Default Re: (RedLinedGSR)
heh damn i hate that stupid thing, it makes my whole car shake. i tried oiling it but it didnt do anything
Old Feb 21, 2004 | 11:49 AM
All Motor DB8's Avatar
i have huh...after you wash da ride ....takes 4ever...lol
Old Feb 21, 2004 | 12:35 PM
AznJohn33's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (All Motor Dc 4)
i just shot the rail things wit some wd40...i think I overdid it though, sometimes I think I can smell it while I'm driving :-P
but it doesn't skip anymore, so mission accomplished
Old Feb 21, 2004 | 01:25 PM
scrolanky's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (AznJohn33)
i applied some powdered graphite to my rails and its been silky smooth ever since
Old Feb 21, 2004 | 01:28 PM
altspace22's Avatar
Powdered graphite, eh? I cleaned all the rails and then applied white lithium and it still shakes. This is a common problem with the Teg.
Old Feb 21, 2004 | 01:51 PM
N1NjA TuRtLE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shupaGSR &raquo;</TD></TR><TR><TD CLASS="quote">get some oem grease from acura, lube that ish up. worked for me.</TD></TR></TABLE>
Old Feb 21, 2004 | 02:45 PM
patmcd's Avatar
Default Re: (altspace22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altspace22 &raquo;</TD></TR><TR><TD CLASS="quote">Powdered graphite, eh? I cleaned all the rails and then applied white lithium and it still shakes. This is a common problem with the Teg.</TD></TR></TABLE>
I was told not to use white lithium because it will collect dirt and make it stick again. Id go to an acura dealer and get some of the oem grease.
Old Feb 21, 2004 | 02:51 PM
ernald711's Avatar
Old Feb 21, 2004 | 03:35 PM
NeoGSR's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (scrolanky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scrolanky &raquo;</TD></TR><TR><TD CLASS="quote">i applied some powdered graphite to my rails and its been silky smooth ever since</TD></TR></TABLE>
i'm gonna try this
any grease/lube it gonna make dirt stick to it.....clean it up real good and put some graphite powder in and i bet it's gonna take care of it
Old Feb 21, 2004 | 03:46 PM
chads99gsr's Avatar
dude hate that. Mine does it too and it fricken annoying. i tried cleaning the rails out and I used the white lithuim grease. Yeah it did nothing for me.
Old Feb 21, 2004 | 05:57 PM
scrolanky's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (chads99gsr)
powdered graphite is so fine that it works really well....lil farming trick from up here in canada
Old Feb 21, 2004 | 06:07 PM
grlstockb18c1's Avatar
I have a 95 and that **** does it to mine too. Its sooo annoying. i cant stand it I'll take some hinters and do it when the weather starts to warm up
Old Feb 21, 2004 | 06:24 PM
alfaaay's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (girlieb18c1)
My freakin' sunroof does the Harlem Shake like no other. It's annoying, but as long as it doesn't get stuck or anything, I don't really mind it. It doesn't do it when I'm closing it at least.
Old Feb 22, 2004 | 01:26 AM
PlastikOwl
Guest
Posts: n/a
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (alfaaay)
95...and mine works perfectly
And...I did nothing to accomplish this..muahahah!
Old Feb 22, 2004 | 06:54 AM
Teggin2's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (PlastikOwl)
i put vasoline on mine and it works perfect because vasoline will never go away or evap like other greases worked great for me
Old Feb 22, 2004 | 09:26 AM
NastyGsr94's Avatar
Default Re: HOW DO YOU MAKE YOUR SUNROOF SLIDE BACK SMOOTHLY?? (Teggin2)
wow at least im not the only one whos sunroof does that, i think ill try some of that powdered graphite
Johnytang
Aug 2, 2004 07:38 AM
monkmonkman
Mar 18, 2004 09:23 AM
randomwalk101
Sep 29, 2001 08:17 AM
Cow
Sep 21, 2001 11:10 AM
keys
Aug 8, 2001 05:59 PM
