GM Synchromesh and bad mainshaft bearing
Old Feb 21, 2004 | 02:01 AM
98GeeYes-Are's Avatar
Default GM Synchromesh and bad mainshaft bearing
It looks like my mainshaft bearing needs to be replaced. It makes a spinning/grinding noise when the clutch is not pressed, but stops when the clutch is pressed to the floor. The noise comes back again about an inch before the top. It also makes a bit of a whinning noise when I drive, so I'm guessing this is the mainshaft bearing. (someone correct me if I'm wrong) I doubt it's the throw out bearing cause it has been replaced. Anyways if I put in the GM synchromesh will the grinding noise go away? Surely someone has had an experience as the mainshaft bearing is a common problem.
Old Feb 21, 2004 | 03:25 AM
Garrett's Avatar
Default Re: GM Synchromesh and bad mainshaft bearing (98GeeYes-Are)
Use GM syncromesh "FRICTIOn modified" they have 2 kind, friction modified is the one you need
Old Feb 21, 2004 | 01:27 PM
Default Re: GM Synchromesh and bad mainshaft bearing (Garrett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett &raquo;</TD></TR><TR><TD CLASS="quote">Use GM syncromesh "FRICTIOn modified" they have 2 kind, friction modified is the one you need</TD></TR></TABLE>
Will it help with the bearing problem, or just with the synchros?
Old Feb 22, 2004 | 06:09 PM
93 EG
12
Mar 3, 2007 08:14 AM
00siandrew
Apr 13, 2006 05:09 PM
AJxr
21
Jan 11, 2006 03:21 PM
bLuEciVicGuY
May 13, 2003 12:39 AM
