Newbie questions
I'm going to help a friend (Mark) mod his 2000 Prelude SH. I'm a Subaru guy, don't know much about hondas. What are some good basic starting power mods. I'm thinking DC ceramic headers, AEM intake, an exhaust. What else? ACT clutch?
Thanks in advance
Thanks in advance
That all sounds good for some basic mods. I know a larger TB and a tune might help also. I would watch the ACT clutch though. I am sure you aren't going too extreme with the clutch. If you would like my opinion, I would go with Clutchmasters or Clutchnet. They are very good clutches, and don't have as harsh an engagement as the ACT. Also the ACT works your Hydraulics, the others aren't as hard. Don't get me wrong I like my ACT, but I will be switching to Clutchmasters soon!
Add another vote for Clutchmasters.
In addition to your basic list consider lightweight flywheel and adjustable cam timing sprockets. http://www.unorthodoxracing.com is what I'm aiming for.
The ultimate mod is the Quaife ATB LSD, $895. The power's no good if you can't put it to the ground.
I also say add pullies and a lightened flywheel (fidanza) to the mix. Personally I wouldn't use clutchmasters or ACT, I'd use RPS or Exeddy. I've heard a few horror stories about clutchmasters and ACT.
Gabe
[Modified by Gabe, 11:29 AM 10/12/2001]
Gabe
Dude, maybe if you've got mega horsepower, but how much clamping power do you need? ACT extreme pressure plate will have you replacing clutch master cylinder.
ive never heard a problem from anyone who has an RPS. supposedly those things are the best. Exedy is top notch as well.
Gabe
What engine does he have? ie engine code. I know it's a 2.2 DOCH VTECH(right?)
What are the differences between the SH model (which he has) and the other models they have. Which is the best to have?
Thanks,
Mike
Thanks,
Mike
97+
you have the base model and the SH model. The SH has an active diff (ATTS) that helps it corner better through turns.
Base model is just minus that system.
Yes, its' the H22A4 in both. DOHC 2.2 VTEC
CW-ITR-329
Mar 8, 2002 09:33 PM
