Aftermarket rear LCA intall?
I'm having a set of rear T-6 Billet Aluminum LCAs installed since I had the pleasure of both lower shock mount bolts snapping off, grinded the old shocks out, then torched both seized bolts/bushings out of the old LCAs. Another nightmare indeed.
My question is for all who have the aftermarket LCAs. I've noticed some of the mounting is different from stock, such as bolts and location of swaybar end link.
Does anyone have any info on this install? Thank you!
https://honda-tech.com/zerothread?id=437142
this is a good writeup on an SRR LCA install, just remember to put them in right-side up. Hope it helps.
I purchased my LCAs thru here. Check the performance thread.
I also know I'll need a 2cm washer and bolt for each swaybar end links because the stock LCAs are threaded and it would seem all of the aftermarket are not.
blarue09
Jun 9, 2015 10:22 AM
