Creeking sound... 99 civic
It sounds like a creeking sound coming from thr front of the car. Only happens when you start and stop, loading the the front end off the line makes it happen only for a second. It's not the clutch, and the axles are good as you can turn and do figure 8's without a sound. I've been under the car with a bar and pride on the LCA, ball joints, swap bar and anything else I can see, and still nothing. It only happens when the car is lowered (2.75), after I raised it up, the sound mostly goes away, or is at least very quite. It sounds like maybe a dry bushing, but they all seem fine. Anyone else shed some light on this? I have another friend with the same car and has the identical sound...we have been to some shops, and the techs are just as puzzled
thanks
thanks
Clairvoyant
Apr 18, 2007 03:51 PM
