62mm or 65mm throttle body with skunk2 intake manifold
Old Feb 20, 2004 | 11:23 AM
ddong2lee's Avatar
Default 62mm or 65mm throttle body with skunk2 intake manifold
in a 97 civic gsr...
will there be a big difference in using a ITR throttle body which is 62mm than a edelbrock throttle body which is 65mm with my skunk2 intake manifold? anyone have it on their setup?
i think the skunk2 intake manifold has a bore size of 64mm? correct?
btw..im going to turbo it sooner or later.
Old Feb 20, 2004 | 11:41 AM
DOHCtorTHRUST's Avatar
Default Re: 62mm or 65mm throttle body with skunk2 intake manifold (ddong2lee)
ITR is 64mm... and you should use a TB that is that size or over that size for the manifold... if not then the TB will be a bottleneck
Old Feb 20, 2004 | 12:11 PM
ddong2lee's Avatar
hmm..i always thought it was 62...o wells.. whatever...
i also thought about gettin the edelbrock TB and boring the skunk2 IM to port match TB.
anyone have any clue on about how much it would cost to bore the intake manifold 1-2 mm? i know it depends on the shop but just want some experiences from people...
Old Feb 20, 2004 | 12:13 PM
99blackcivicSi's Avatar
i had a 68 on my skunk2 i am boosted though made a big diff all through out the powerband by the but dyno
Old Mar 1, 2004 | 10:22 PM
shivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddong2lee &raquo;</TD></TR><TR><TD CLASS="quote">hmm..i always thought it was 62...o wells.. whatever...
anyone have any clue on about how much it would cost to bore the intake manifold 1-2 mm? i know it depends on the shop but just want some experiences from people...</TD></TR></TABLE>
boring your manifold for a t/b will run you 50 bucks. try not to pay any more than that.
Old Mar 2, 2004 | 04:22 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddong2lee &raquo;</TD></TR><TR><TD CLASS="quote">in a 97 civic gsr...
btw..im going to turbo it sooner or later.</TD></TR></TABLE>
Why don't you bore the GSR throttle body instead.
I can bore it to 64.5mm and it will work just fine with the skunk2 manifold.
It will only cost you $100, click on the link on my signature for info.
Old Mar 2, 2004 | 04:25 PM
Spade's Avatar
ITR is 62mm you were right.
Old Mar 13, 2004 | 03:55 PM
Boosteddc2gsr's Avatar
what is astock gsr tb bore size??
Old Mar 13, 2004 | 05:34 PM
Spade's Avatar
Default Re: (vandilist)
60mm
YoungMoneySi
Apr 24, 2006 06:56 AM
57one
Feb 28, 2003 01:58 AM
LeftCorner
Sep 12, 2002 12:59 PM
JM Performance
Jul 23, 2002 05:24 PM
