are four door integra and civic seats interchangeable????????????
REAR SEATS SPECIFICALLY>>>>>>>>>
thanks,
4 door civic and 4 door integra
sorry thought i put that on title..
mike
Modified by impound at 11:11 AM 2/21/2004
Modified by impound at 8:53 AM 2/22/2004
Modified by impound at 6:03 PM 2/22/2004
thanks,
mike
If you the them for a 92-95 civic from a mid to late 90's integra you should be good. I am not sure about the 98-01 tegs but I know the 94-97 will because I have them in my hatch.
sorry ......my fault....92 eg 4 door / dc body integra 4 door (94+)
Modified by impound at 2:32 PM 2/20/2004
From: Why so you can pretend like youre interested, FL/OK
The 1992-95 Honda Civic seat is interchangeable with the 1994-97 Acura Integra. But if there were a problem, worst case scenario is changing the rails from the seats. Any way it goes this seat swap will work.
I am nearly 95% positive the rear seats will work, it's only bolts holding the seats into place. Never have I seen where the 2dr or 4dr back piece integra seats wouldn't fit in a hatch. So I wouldn't see why it that wouldn't hold true with the 4dr. I doubt there would be any gap on the buttom cushions as well (only on 4drs). I have matched up 2dr integra seats in a 4dr civic, it won't work. Again, I am 95% sure it will work from a 4dr. Request seat measurements.
if youre trying to get integra seats in the rear... the best way to do with (eliminating as many gaps as possible) is to get the back piece off a coupe teg and the bench piece from a sedan teg
I thought the whole deal with DC Teg seats into an 2dr EG were that you IDEALLY WANT 2 door front seats (so they fold forward) and 4dr rear seats... because there is less gap...
I know I searched on this a while back and that seemed to be the concensus.
4door teg rears and 2 door teg fronts are the best fit in 2/3dr civics...
Someone correct me if you KNOW I'm wrong.
has anyone seen 4dr rear pieces? They didn't work when I tried it. There is either 3 or 4 pieces. theres like two inners and two outers.
the 4 door rear seats will not fit into the rear of a civic, only the bench part, but the part where your back goes wont fit, you need a 2door teg part for that
4 door front seats fold forward as well
Modified by _randeEe at 10:43 AM 2/21/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _randeEe »</TD></TR><TR><TD CLASS="quote">the 4 door rear seats will not fit into the rear of a civic, only he bench part, but the part where your back goes wont fit, you need a 2door teg part for that
4 door front seats fold forward as well</TD></TR></TABLE>:-)
This is all four door, into four door for those mentioning 2/3 dr and gap issues.
thisisntjared
12
Aug 21, 2005 01:14 PM
